10-24-2016, 05:55 PM
Pushing into the cold...how far?
I have one last trip next weekend. Looks like a couple of 32F nights and maybe one below 30F between now and then but mostly well above 32F. These lows this time of year are typically only for an hour or two during the early morning.
How concerned should I be? I plan to keep an electric heater set low at 50F and open all cabinet doors. But I know there are low points outside, etc. I'm thinking I'll be fine since it isn't a hard freeze. Anyone think otherwise?
2015 Shamrock 233S
2007 Ford Expedition EL Eddie Bauer
2016 Nights Camped = 22
2017 Nights Camped = 11
10-24-2016, 06:10 PM
Temps need to be 28F or lower for several hours before the lines will freeze. You may want to protect the water hose from the spigot to the RV.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
10-24-2016, 07:48 PM
You should be ok but if you are worried, drain your fresh watertank and water heater. You'll still have a bit in your lines but for the limited time you're talking about, shouldn't be a problem.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
10-24-2016, 08:21 PM
With temps like that there is no need to dump your freshwater tank nor the hot water tank. Leave your water heater on and there is no issue. If you have the electric option on your water heater you won't be using up any propane by doing so. As you say it will only be at those temps for probably a couple hours. We have camped many times in the fall with temps getting to 28 and had no issues. You will have heat on in the trailer and some of that heat will get into compartment areas. To be safe I would disconnect your potable hose at the spigot and reconnect once the temp sneaks back up.
Keep in mind water doesn't go from liquid to ice as soon as temps drop below 32, it is a gradual process...I live north of MN, in Canada...so I know winter and bone chilling cold, so I speak from experience.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
10-24-2016, 08:33 PM
We are to get snow here either Tomorrow or Thursday. Temps will hover around freezing. I have not winterized and not worried.
B and B
10-24-2016, 08:55 PM
Snow in Ontario before we get snow here in Manitoba???? Say it ain't so!!!
10-25-2016, 12:34 PM
X2- Only becomes an issue if daytime temps were to stay below freezing.
10-25-2016, 12:37 PM
Senior Senior Member
If it's that chilly at night you will be keeping the inside warmed up and unless it dips below the mid 20s you should not have a problem except for your outside water line which you could just undo the night before.
We had four nights in the 20s at Yellowstone in May.... no issues whatsoever. I was a bit nervous when we came back to camp and saw the ranger's advisory that the water would be turned off at night due to the cold but we just burned a bit of propane to stay comfy and had a good nights sleep.
2015 Flagstaff Super V 26VFKSS Emerald... SOLD
Now camping with a new SOB Winnebago pulled by a 2021 Ford Ranger.
10-25-2016, 01:08 PM
Phat Phrog Stunt Crew
If you staying in a full hook up park you can open your drain and then run the water at a trickle the size of a pencil. Running water doesn't freeze or you can disconnect you outside hose and keep some heat on the RV.
2014 Wildcat 327ck
10-25-2016, 01:39 PM
We have camped in the mountains in Colorado in late October. The rules there are to disconnect your water line over night. If you don't & their
outlet freezes, then you're responsible. So we fill the fresh water tank, disconnect & drain our water line & turn on our tank heaters.
All the water outlets there are covered in heating wires.
Over night we use a portable heater with a thermostat as it is so
much quieter than the furnace. Then in the morning we reconnect the
water line for showers etc. No problems and the temperature was down
around 28F overnight.
10-25-2016, 01:52 PM
Gonna go camping this weekend in Colorado. Don't use campgrounds. Heating ducts run next to tanks and do good job of preventing freeze issues. Hope to get some atving in too.
10-25-2016, 02:32 PM
I would not be concerned at all. We take trips after winterizing, gallon jugs of water as needed to flush the toilet, wash in a basin and it get tossed in the black tank.
Retired Paramedic
2020 FSX 280RT
2005 Silverado 1500 Ext cab 5.3 H.O.
2011 HD Road King
Nights camped since 2019.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
10-25-2016, 02:46 PM
We're planning to go all winter long, but the temps where we'll be shouldn't be below freezing.
Was in the mountains earlier in the month and I was monitoring the weather. Before bed, forecast lows were 34. Not bad. Woke up to a hard freeze warning in effect and 29. Yay. Water hose frozen solid, water spigot froze open, tank valves frozen closed. Lesson learned: Run them tank heaters and disconnect that hose! (And keep a hair dryer in the drawer just in case)
2017 Rockwood MiniLite 2506S
2022 F250 7.3/4.30
10-25-2016, 02:52 PM
An old hair dryer stored in the water storage compartment is a great idea!
10-25-2016, 04:59 PM
Thanks all! Happy to be pushing it this late into the season. Weather looks decent for the next 2 weeks.
2015 Shamrock 233S
10-25-2016, 07:18 PM
We got down to 14F last fall, warmed up the next day. Water hose froze so shifted to on board tank, no worries. Next morning reconnected and all was well.
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
10-26-2016, 08:06 PM
Winter camping?
What campgrounds are you still able to stay at this weekend??
