Old 10-24-2013, 11:27 AM   #11
Our 2014 works just fine. We leave all 3 beds plugged in all day at 6 and dial it down when we get into bed.
Dropped to 2C last weekend when we were out and we were nice and warm inside. It keeps our bed nice and warm even through the 1.5" foam topper we have on top of it
2013 F-150 XTR Ecoboost 4x4, 3.73 w/Equalizer
2014 Roo 233s
Nights camped 2014: 28
Nights camped 2013: 17
Shado is offline   Reply With Quote
Old 10-24-2013, 11:49 AM   #12
I don't have a topper maybe I need something to trap and hold the heat. Don't get me wrong the beds are not cold just not warm not until I'm on them. Then they work awesome
Boat67 is offline   Reply With Quote
Old 10-24-2013, 12:04 PM   #13
clancythecamper's Avatar
IMHO, the heater seemed to keep the mattress comfy, not really heated per se. We did use our topper and blankets and were comfy with temps in the 40's.
clancythecamper is offline   Reply With Quote
Old 10-24-2013, 05:08 PM   #14
The heated mattress only work when their is pressure put on it (laying on it). We use ours with 4in memory foam on top it works well we turn it up when we put topper on then turn it down at bedtime
CamperCar is offline   Reply With Quote
Old 10-24-2013, 05:32 PM   #15
The heaters are only about 150 watts, basically as much heat as a good sized light bulb. They are NOT like electric blankets. I found this out the hard way. First time I tried them, I kept putting my hand under the covers, expecting it to be warm like an electric blanket. The plug is very hard to get into the fitting on the mattress, so I thought it wasn't getting in far enough to make an electrical connection, so I "filed" down the outside of the plug, hoping I could get it in better. (Didn't help, but it made it look ugly.) Ended up giving up and getting into bed, and discovering an hour or two later (the wife had turned it on, even though I had given up) that it was quite warm in there! Then I read here that it's only about 150 watts.
2011 Traverse LT, 3.6L, FWD
Old 10-24-2013, 06:20 PM   #16
GlacierGus's Avatar
I have a 3-4 inch topper. I use an electric blanket. I doubt that the mattress heater would get through the topper. If you have shore power anyway, I believe an electric blanket works better.
2013 Rockwood Mini Lite 2109S
2006 Dodge Durango Hemi 5.7
Equal-i-zer WDH
GlacierGus is offline   Reply With Quote
Old 10-24-2013, 07:02 PM   #17
Ford Idaho's Avatar
Would it be a good or bad idea to put something like a space blanket under the mattress to direct the heat up?
Old 10-24-2013, 07:12 PM   #18
Rrickim63's Avatar
Never tried it. Cant hurt..if its really cold you may get some condensation between bunk( cold) and mattress(warm). The heated mattresses work great!
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 10-24-2013, 07:23 PM   #19
Ford Idaho's Avatar
I put one under the foam mattress in the old Bell pickup camper I had, it helped some or I thought so but it was not heated .
I wondered if it would cause a problem with a heated mattress.
Old 10-24-2013, 07:53 PM   #20
mTn_biKer65's Avatar
You're about to discover the wonderful world of heated mattress's in a hybrid. If you're like me you sleep better when the furnace isn't cycling on & off all night. Turning up the mattress means you can turn down the furnace a degree or 2.
p.s. don't forget to crack a window or vent to help control that condensation under the mattress and on the windows when the temperatures get colder.
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS -
2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
mTn_biKer65 is offline   Reply With Quote
roo
