Old 06-19-2019, 02:33 PM   #1
Quieting the water pump
I have had much noise from the water pump. I have put some dense foam under the pump. I want to put a few inches of horizontal pipe on either side of the pump. I have both Red and Blue Pex but I also have a clear white reinforced pipe with a blue stripe. Are they all supposed to be 1/2 inch? It seems the red and blue Pex are smaller than the clear with the blue stripe. Any suggestions would be a great help. My wife sleeps right over the pump!!!!
jrctoby is offline   Reply With Quote
Old 06-19-2019, 02:57 PM   #2
Canadian Member
Since you’ve already put the foam under the pump, the only other thing you can do is to prevent the water lines from vibrating. Secure them however you need to to keep them from vibrating against whatever they’re touching. Maybe use some hot water pipe insulation. All the water piping should be 1/2”. You can also add some extra flexible tube on either side of the pump.
Old 08-24-2019, 10:49 PM   #3
rlh1957's Avatar
Pay atte3 to every hose, connectors, sny pint that ontacrd other surfaces. Cover those with foam pioe insulation.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is offline   Reply With Quote
Old 08-25-2019, 01:11 AM   #4
In the case of my pump on a Shockwave T24RQMX, the fix was to replace the factory installed kinked vent hose which then let me fill the FW tanks without them burping water out. The kinked hose would cause the pump to suck air.
flhtci2006 is offline   Reply With Quote
Old 08-25-2019, 05:09 AM   #5
"On the road again"
rjshiflet's Avatar
Huh???
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
rjshiflet is offline   Reply With Quote
Old 08-25-2019, 11:16 AM   #6
My pump was noisy initially. I solved the problem by removing the mounting screws and reinstalling them IN the holes in the isolation bushings. The installer just ran the screws through the rubber itself and essentially locked out any damping function.
I tightened the screws just enough to hold the rubber against the floor and not enough to compress the rubber bushings.
also moved the pump slightly before screwing down so PEX pipe on the outlet didn't vibrate against the cabinet wall like it did from the factory. All I hear now is the slight "groan" of a properly working water pump but not enough to bother anyone.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
Old 08-25-2019, 01:48 PM   #7
rlh1957's Avatar
Originally Posted by rjshiflet View Post
Huh???
Must have been a chicken pecking that out!
Pay attention to every hose, connectors, any point that contacts other surfaces. Cover those with foam pipe insulation. If it touches it vibrates and transfers sound.
24WS
FX4 Off Road (4X4)
pump, water, water pump
