05-13-2015, 02:42 PM
#21
Speaking of the audio/video system, I was hoping to play a video file off a USB stick plugged into the stereo system this last weekend. I just kept getting "USB input" flashing on the TV, but the file never played. Is this for audio only?
05-13-2015, 06:36 PM
#22
I believe it's supposed to be able to play mp4 short video clips.
2019 Coachmen Freedom Express 281RLDSLE
2018 2500 HD Silverado
Equal-i-zer Hitch E4
05-13-2015, 07:42 PM
#23
Mine played a slide show of pics and music, but the video file was not supported, not sure what type file it was. I'll mess with it this weekend if I get a chance. I tried a regular external hard drive but believe it needs an outside power source to run properly.
Retired Paramedic
2020 FSX 280RT
2005 Silverado 1500 Ext cab 5.3 H.O.
2011 HD Road King
Nights camped since 2019.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
05-19-2015, 08:19 PM
#24
Hey thanks for the info about the audio cable being hooked up wrong. Mine was hooked up wrong too. But it crackled in and out after I made the switch. Had to replace the cable. Now all is good.
Anyone added a subwoofer to get more bass? I see there is a hookup for that on the iRV33 for zone 1.
05-22-2015, 06:57 AM
#25
Kind of off topic but I notice mine has 1 interior speaker per zone, with both exterior to zone 3...is this the configuration you guys are using?
I can't imagine when I would use only 1 interior speaker and the exterior is so quiet I can barely hear it unless I turn off the inside so I can turn it up. I was thinking if I switched the exterior to zone 1 or 2 I could use the balance to tweak inside vs outside.
XLR 24HFS -> Roo 21DK -> RPod 183g
2013 F150 FX4 EB
05-22-2015, 07:16 AM
#26
That struck me as a bit odd as well Vader? Mine is set-up exactly the same way. I can turn on one or 2 speakers in the cabin? zone "C" is both outside speakers? Doesn't make a lot of sense? I thought the outside was so quiet because it was directional and I was over by the door? Not sure how that would work changing it around. Would be interesting to find out.
05-22-2015, 07:57 AM
#27
Is this the iRV stereo? According to the manual, only zone 1 is 2.1 audio. The other two are stereo. I'd rather have 2.1 inside. I'm going to add a sub woofer hopefully today and crank up the bass.
2016 Roo 21SS
2005 Ford Excursion-Sherman
Mods so far:
PI hardwired EMC, Wire Shelving in wardrobe
Plexiglass screen door protector, Blue LED Wine nook
stairs, and counting...
05-22-2015, 08:29 AM
#28
Yep ours is the same, My plan is....
New GOOD speakers for inside, the cabinet one place vertical in the wall above the fridge, hooked up in stereo on zone one.
Zone 2 will get a wireless speaker set for the few times we want to jam out.
Zone 3 will have to do for now
Retired Paramedic
2020 FSX 280RT
2011 HD Road King
05-22-2015, 08:40 AM
#29
Ahhh, thanks...that makes more sense. In the DK with the existing speakers it doesn't really help to have stereo sound because the speakers don't really play well together. I plan to add a sub at some point as well but I think I should be ok moving the outside to one of the 2.1 channels. I will mess around with it a little bit.
Thanks again!
05-27-2015, 02:54 PM
#30
I have a 233s and over the weekend I pulled my stereo out and there is only one cable, a yellow one, that is being used for the video from the TV to the stereo for the DVD player.
Am I missing some cables? I tried plugging in AV red/white from the tv to the stereo but was unable to here any sound out of any modes of the stereo. Is there something I am doing wrong? What mode are switching the radio to in order to hear TV sound through the stereo speakers?
05-27-2015, 03:14 PM
#31
TV audio, make sure they are plugged in from the TV in the audio out. I know where mine where plugged into the radio I had to move them down to make it work. Just try them all should find the right ones. Good luck
05-27-2015, 03:33 PM
#32
Mine has an hdmi cable that goes from TV to stereo so I simply chose that HDMI input. I also have the red/white audio cables running to the tv. No video cable. Honestly in my situation I am not sure why I even have audio cables included.
One other thing to check is the sound settings on your tv. I can't recall the options that were there but there may be audio output options.
05-27-2015, 03:49 PM
#33
My stereo was wired wrong also it had two wires for the back speaker not wired to the back speakers just hanging there and had no control to fade from front to back wired the stereo properly works great . also I added amp and a sub woofer from the subwoofer plug on the side of the stereo so now zone a is all four speakers inside and zone C is the two speakers outside and zone B has nothing yet
Sent from my IPhone
05-28-2015, 11:04 AM
#34
How did you add an amplifier? I connected a subwoofer and can barely hear it. I think I need an amp.
2016 Roo 21SS
Mods so far:
05-28-2015, 09:40 PM
#35
Well I just got a small amp and only used one Channel hook the out put of the radio to the input of the amp and the speaker to the output of the amp used the wire on the radio to turn the amp on and off it made a big difference not tinny any more
05-29-2015, 08:53 AM
#36
Thanks for your reply. Sorry, I know nothing about audio. Hope you don't mind more questions. Does the amp need power to it? If so, how do you supply it? What do you mean when you say "used the wire on the radio to turn the amp on and off "? Thanks again!
Karen
05-29-2015, 10:40 AM
#37
Anyone replace the IRV with something else? I don't use the radio just like it to use surround sound however the Furrino speakers seem to be crappy but TV works well. I hope to connect to cable next trip and try that out.
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
05-29-2015, 02:02 PM
#38
Karen
Ok yes the amp needs 12 volts I got 12 v power from the 12v behind the radio and if your radio is like mine a IRV look at the wires that come off the back of the radio they are marked. look at the ones that are not hooked to any thing can't remember what Color it is I think the tag says auxiliary amp that wire will turn your amp on and off with your radio on and off button but you still need to have a constant 12 V to the amp now the easy way is to go to Best Buy and buy a small amp and sub woofer and have them install it for you hope this helped have a nice day
Sent from my IPhone
06-07-2015, 04:06 PM
#39
Not sure I'm following this post, but is it my understanding that the TV sound should be able to come out of the camper (radio) speakers? Ours currently only comes from the TV. Sure would be nice if the TV sound came out of the camper speakers too. Have a 2014 Coachmen 288BHS trailer.
06-07-2015, 04:47 PM
#40
Yes should be able to come out of the radio also when set on TV audio.
