Old 04-14-2016, 07:36 AM   #21
MiCamper6's Avatar
Lippert, the manufacturer of the frames under these Roos, offers a bolt-on receiver that won't void your warranty provided it is installed by a 'qualified technician'.
MiCamper6 is offline   Reply With Quote
Old 04-14-2016, 08:02 AM   #22
TURBS's Avatar
Would like to see the literature on this please.
Old 04-14-2016, 08:19 AM   #23
MiCamper6's Avatar
Might I suggest you check their web site, as I had done in the recent past?
Old 04-14-2016, 09:02 AM   #24
Justice12t's Avatar
That is interesting...Lippert told me that if I bolted, welded or modified my frame in anyway that it "could" void the warranty. Now I say that having a 5'er with a different frame than the OP.
My dealer contacted Lippert (I have a thread somewhere out there about it) about installing a lippert component for bikes and what not by my dealer's master fabricator. Lippert responded with...something along the lines of...It is a case by case basis, IF you have a frame failure then they or you will have to prove what caused the failure. If it is proven that the modification to the frame caused or attributed to the failure than they have cause to deny the claim.
I want to point out that I was never told...that it "would" void my warranty...just basically it will be much more of a pain to prove it out...
I am having my buddy do it A) because I trust me B) because it is much cheaper than the dealer...
2016 Prime Time Crusader 294RLT
2016 Days Camped - 31
2017 Camping Blues - ...
Justice12t is offline   Reply With Quote
Old 04-14-2016, 09:08 AM   #25
TURBS's Avatar
I looked, I found zero documentation to support your claims.
Old 04-14-2016, 09:08 AM   #26
B and B's Avatar
Originally Posted by Papa-t View Post
Ok I have said this many many times on different forums that I was a member of when I had different brands of campers. Yes it might void a frame warranty and it might not. Do you want to use your camper or not? Take it to a welding shop or someone that is highly recommended and have a custom hitch cut and welded to the frame with heavy tubing. They will of course have to drop the back underbelly to get to the frame so they can weld heavy tubing across. If you want to use your camper then have one made and enjoy it. But I will add that my trailers were larger 5ers so that could be a deciding factor. The frames on the ones I did it on were heavy frames. And this is just my opinion. I would never want to give anyone advice that would endanger them or anyone else. It has to be your decision. Maybe have someone to inspect your frame to see how heavy it is and if it is strong enough to do the job.
I have a 32 ft Rockwood Ultralite. No way I would weld or attach anything. I mounted a Arvika bike rack to test this. Used a Go Pro and drove around the block, returned home and took it off. I wish I kept the video, it was before I was on this forum.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 04-14-2016, 09:10 AM   #27
TURBS's Avatar
To the op, I've done it. It didn't end well "first hand experience"
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
Old 04-14-2016, 09:11 AM   #28
B and B's Avatar
I remember asking Lippert at the Goshen rally for solutions for mounting bikes on the back of a Rockwood. Was told nothing they sell would be suitable and any modification would be a warranty violation.
Old 04-14-2016, 09:12 AM   #29
Justice12t's Avatar
Thank you for getting this back on track. We started down the bike path and the OP was talking about fire wood and coolers. Neither of which I would even put on the back of my unit.
Old 04-14-2016, 09:17 AM   #30
Georgia Frog Rally 2018
aceinspp's Avatar
Yep my new camper got a sticker inside cabinet door say if you attach anything to rear bumper it will void the warranty. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
camper, hitch
