Old 07-25-2015, 08:13 PM   #1
Rodney Butalla's Avatar
Recharging batteries
Does anyone know if i can charge off the 7 pin plug with the TV running at the same time i use a 480 watt inverter hooked to the TV and a 12 amp charger hooked to the batteries to charge?
Rodney Butalla is offline   Reply With Quote
Old 07-25-2015, 08:44 PM   #2
HONDAMAN174's Avatar
Most tow vehicles send 15 amps thru 7-pin plug. Some big boys send 30 but not at idle- and may have to turn on lights to do this. A 400w inverter pulls about 35 amps at full load.
Better question is how many watts you will be using.
Just glad to get away
charging, battery
