09-29-2015, 08:55 PM
#41
Originally Posted by nomad297
The Husky Center Line TS.
Bruce
I'm very impressed with that hitch.
09-30-2015, 09:13 PM
#42
Originally Posted by Summer2Go
So maybe they should've sold me a different hitch. The Equalizer keeps the trailer totally in line, though. If I ever go bigger in a trailer, I will keep the hitch, after all I have gone through breaking it in!
Summer: If you get a bigger TT, you MAY need a bigger hitch. The Equalizer comes in various sizes. The spring bars are heavier-duty for heavier TT's. Don't know if the hitch head is different or not. Example: I had a 400/4000 hitch for my Roo, but now have at 600/6000 hitch for my Mini-Lite.
2011 Traverse LT, 3.6L, FWD
10-02-2015, 05:17 PM
#43
Summer2Go
You're kidding! This hitch seems over done for my 183. But I don't think I will ever go much bigger than a 25' trailer. I'm learning on this one. We'll see.
10-06-2015, 08:52 PM
#44
I'm hearing the Husky centerline is very heavy. Anyone confirm that?
10-06-2015, 08:56 PM
#45
Blue ox sway pro.
Loved it with my TT.
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
10-06-2015, 09:18 PM
#46
all WDH are big chunks of steel designed to pull and carry heavy weights safely... they all weigh allot... the heavy adjustable shank that goes into your 2" receiver mounted on your TV along with the 2 5/16 hitch ball attached with nothing else attached will weigh around 25-35# I would guess.
Once you have that shank part mounted into your receiver, then you install onto the shank the additional torsion bars and sway controls (depending on what make/model) onto that shank that then hook to your trailer. Total weight of all that steel will be over 50# and probably closer to 60-65# once everything is hooked to your TV.
If you are wary of carrying that weight and installing it into YOUR receiver, then remember, the hitch all starts with the shank portion, and once that is installed you build up the hitch with additional parts for the final package to pull your TT.
I hope that helps answer your concerns...
2014 Shamrock 183
10-06-2015, 09:30 PM
#47
Andersen WDH is the lightest hitch by far on the market. Easy setup, no grease, sway control built in...works great. I would look into it if you are concerned about the weight of the hitch!
10-06-2015, 09:50 PM
#48
I usually left my blue ox on the truck.
Got rear ended. Nothing major, but crumpled his hood.
Blue ox 1.
Cavalier 0.
2008 F350 CCSB V10
2016 Sabre 36QBOK
10-06-2015, 10:31 PM
#49
X2
2015 Flagstaff 8528IKWS Diamond Package
2013 Ford F-150 Super Crew, EcoBoost, Max Tow,
6.5 bed, Roadmaster Active Suspension, E rated tires
98 days camping 2017 98 days camping 2018
94 days camping 2019 49 days camping 2020
10-07-2015, 05:56 AM
#50
I guess it is Same weight as equalizer.
10-07-2015, 06:42 AM
#51
Originally Posted by bikendan
For the 183, the cheaper E2 would be fine.
But the 4 point Equal-i-zer would also fit, if that's what you want.
X2.
I use an E2 Trunnion and it works fine with my 23' trailer.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
10-07-2015, 06:53 AM
#52
Georgia Rally Coordinator
Originally Posted by pxt
Don't think I'll go any bigger anytime soon.
Famous last words . Heard that one before Never go cheap on a hitch. You'll regret it. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
