Old 10-07-2012, 02:01 AM   #11
Herk7769's Avatar
Originally Posted by phygenius View Post
Our used 2009 Roo 21SS has the Dometic DM2652 abosrbtion refrigerator. The only indication of a temperature control is a plastic clip that slides up and down one of the cooling fins in the main compartment with a decal on the side of the unit that suggests temperature control. As an engineer, this makes no sense.
Everything except on the bottom most shelf is frozen solid.
Any other adjustment available in the control unit?
The plastic clip contains a "thermistor" and sliding the clip up and down the fin regulates the temperature by calling for "the fixed temperature of the thermistor" at that elevation in the box. It is called a "Temperature Sensing Device" in the manual on page 5 (Under "LIMP MODE OF OPERATION").
I keep it in the center of the fin and it works perfectly. (Beer cold; eggs not frozen).
"coldest positions in the refrigerator are under the cooling fins and at the bottom of the refrigerator. The warmer areas are on the upper door shelves. This should be considered when placing different types of food in the refrigerator. Arrange all food in the unit to allow for free air circulation."
From the manual.
There is also a failure mode of the DM2652 that will cause the refrigerator to run constantly until a new sensor is installed and the system reset by removing DC power from the unit.
HAM CALLSIGN - KC3FFW
Old 10-09-2012, 07:56 PM   #12
Wally Roo
phygenius's Avatar
Minutes after posting the question, I found the thermistor dangling at the bottom of the unit. I put it into the clip and now have some control on the temp.
_______________________________
2009 Rockwood Roo 21SS
2012 Nissan Frontier
Rocky Mountain National Park
phygenius is offline   Reply With Quote
Old 10-09-2012, 10:47 PM   #13
Herk7769's Avatar
Badda Bing...
Old 08-27-2014, 11:09 AM   #14
Herk,
I know this is an old thread, but may I resurrect it to deal with a problem I am just having? My DM 2652 always stayed at 36-44 degrees depending on outside temp. On this trip, roads were rough and the plastic slider and thermistor fell off. I think I know how it went on, but when I replaced it, I cannot get the temp below 44 degrees. Doing a Google search, I found several people saying the thermistor must be in contact with the fin, which is not going to happen with this plastic slider. Do you (or anyone else) have a picture of how the thermistor fits in the slider, and the slider on the fin? Right-most fin? etc.
Thanks in advance.
K_and_I
K_and_I
K= DW and I
2017 Ford F250
2011 Rockwood 2604
K_and_I is offline   Reply With Quote
Old 08-27-2014, 11:30 AM   #15
Crusader's Avatar
Originally Posted by K_and_I View Post
Herk,
Thanks in advance.
K_and_I
I will get you a pic tonight when I get home. I installed a fan in mine, works great!!!
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 08-27-2014, 11:35 AM   #16
raspivey's Avatar
http://i195.photobucket.com/albums/z...e/1f9d017f.jpg
Old 08-27-2014, 11:38 AM   #17
Thanks- I'll watch for it. I see you're from Michigan. We're in a campground in the Leelaunau peninsula for the week.
K_and_I
K_and_I
K= DW and I
2017 Ford F250
2011 Rockwood 2604
Old 08-27-2014, 11:41 AM   #18
Originally Posted by raspivey View Post
Thank you for the picture. That is how I thought it should go, but I find that it is not changing the temp no matter where I put the slider.
K_and_I
K= DW and I
2017 Ford F250
2011 Rockwood 2604
Old 08-27-2014, 11:49 AM   #19
raspivey's Avatar
Mine doesn't change much. As I understand it, almost all of them are that way. All the way up, I'd notice drinks start to form ice in the door if I left it closed for 6 hours or so. About halfway down, the ice stopped, but it was still really cold. I've never checked the temps on it. It's possible that it's got a wire damaged or something like that if the temp won't come down and it used to (although it's more likely it would go the other way and be too cold...I'm not really familiar with how a thermistor works).
Old 08-27-2014, 12:02 PM   #20
Herk7769's Avatar
Thanks for helping as I am traveling ATM.
