Old 08-27-2014, 12:05 PM   #21
Thanks again, all. I guess I'll keep an eye on it. It seems strange that it cooled into the 30's regularly until the thermistor bounced off. Maybe we're just opening the door too much. I appreciate your assistance.
K_and_I
K= DW and I
2017 Ford F250
2011 Rockwood 2604
K_and_I is offline   Reply With Quote
Old 08-27-2014, 04:50 PM   #22
K_and_I:
I'm probably pointing out the obvious, but:
Not only does the slider move the thermistor up and down, the thermistor slides up and down inside the slider. So you may have the slider where you used to put it, but the thermistor may no longer be in the same place in the slider. Ultimately, it's the position of the thermistor, not the slider, that counts.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 08-27-2014, 05:42 PM   #23
raspivey's Avatar
That's a good point. I had forgotten...mine had done the same thing. I had to hold the wire and make sure they moved together when I adjusted mine. The slider moved, but the probe didn't.
Old 08-27-2014, 08:29 PM   #24
Originally Posted by rockfordroo View Post
K_and_I:
With me its always a good idea to state the obvious, but this time I was aware of that and watched the location of the thermistor. Again, thanks to all who responded.
K_and_I
K= DW and I
2017 Ford F250
2011 Rockwood 2604
Old 08-27-2014, 09:20 PM   #25
If you've got the thermistor back in the proper spot, it's possible you've damaged it.
Old 09-19-2014, 02:13 PM   #26
PAWDWCamper's Avatar
Can anyone take their slider off and post a picture of how the thermistor fits in the slider?
I am having a similar problem but I don't see a right way to put the sensor in the clip.
PAWDWCamper is offline   Reply With Quote
Old 09-19-2014, 06:31 PM   #27
I visited a major RV repair center and the technician placed a piece of double face tape inside the slider and fastened the sensor to the tape. Works in my unit!
l001952119 is offline   Reply With Quote
Old 09-19-2014, 07:21 PM   #28
Repair KIt
This may be a solution to your problems. I have in writing from Dometic that having this installed will NOT void the warranty on MY unit. You may want to contact them about the same. The product also states it should be installed by a professional, but easy enough for most to do.
This was Dometic's response:
"David,
No problem, you can have this installed and it will not affect the warranty. I just wanted to ensure you did not have any out of pocket expenses while you are within your warranty period. "
Sincerely,
Erin Rager
Now maybe "having it installed" and "installing it" might be two different things and a way for them to back out of warranty but you can figure it out. I have not installed one of these yet as my fridge (which has temp control buttons) does a good job so the thermister is not a problem for me.
Hope this helps:
Dometic Thermistor Repair Kit
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 09-19-2014, 07:25 PM   #29
I am on a road trip with it right now, I will try that when we get back home. Right now we are trying to get it fixed so our milk and lunch meets stay good.
Old 09-26-2014, 06:52 AM   #30
Dave Lyon's Avatar
The sensor bulb is not supposed to move inside the plastic thing, it's supposed to move WITH the plastic thing. When you slide the plastic thing up and down, you raise and lower the sensor. Last time I started up my fridge it wouldn't get cold. The sensor had fallen out of the plastic thing and was laying on the shelf below. (It's not a very tight fit, unfortunately.) Based on that experience, I would have thought you'd have trouble keeping it cold, not with freezing. Anyway, move the sensor up and down and see what that does.
Well this explains alot. Mine has been sitting in the tray below since day one. I though it was supposed to be this way and thought the whole "slide" system was odd.
Does anyone have a picture of how the bulb should be positioned in the slide?
Thanks.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
