Old 06-30-2015, 11:30 AM   #11
That sounds like it would correct the unscrewing itself problem but it would not have prevented my situation. One step at a time for fr. And I don't mean to sound down on FR. We've had our camper for a bit over a year and this is the first problem. Overall very satisfied. It just seems like this is a well documented issue and no changes have been made to correct it.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is offline   Reply With Quote
Old 06-30-2015, 03:07 PM   #12
Not sure if this helps during my PDI they said when you winterize make sure there is no water on the canister threads. When the water expands it cracks the canister and then it continues to split. I use the compressed air method and leave the canister off during the winter.
edcronin01 is offline   Reply With Quote
Old 06-30-2015, 03:08 PM   #13
RooVader's Avatar
Now that is one quality PDI.
XLR 24HFS -> Roo 21DK -> RPod 183g
2013 F150 FX4 EB
RooVader is offline   Reply With Quote
Old 06-30-2015, 03:14 PM   #14
Don't know about the winterization as I had the dealer do it the first time. Sounds like a possibility though since that is exactly what happened to mine. Thanks for the heads up.
Jim and Deb
2013 Ram 1500
Old 06-30-2015, 03:16 PM   #15
Originally Posted by jking46 View Post
Got set up last weekend. Everything good but faucet sputtered with no water pressure. Went around back to check the pump. Opened the door to find water spraying everywhere. Filter housing had split. Shut off pump, removed filter, cut lines, made short trip to nearest town. Ace Hardware had Sharkbite connector. Made connection and all was good. Should have listened to all the good advice on this forum and made the change at home, not in the field. By the way, why is FR still using these things?
FR is still using 'these things' because they are an inexpensive solution, and FR is in business to make money.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 06-30-2015, 04:15 PM   #16
The first thing that I did last year was pull out the water filter that was just about inaccessible and bypass it and go with a walmart external filter. No more winterization problems.
bruane is offline   Reply With Quote
Old 06-30-2015, 06:10 PM   #17
Does this shark bite connected come in different sizes. What should I get? Roo23 IKSS 2015. Will I need extra tubing to connect the two pieces back together?
syogerst is offline   Reply With Quote
Old 06-30-2015, 07:07 PM   #18
DaveSchwartz's Avatar
When I removed mine, one side had about a 2" reinforced vinyl hose section with a PEX crimp ring. I cut the crimp ring off with a diagonal wire cutter and slid the barbed end out of the hose. After removing the canister and wall bracket, I could just turn it off the other fitting (which was an elbow into real PEX). Then I found a double-female connector with the right thread (for $0.89CDN), threaded in the straight connector that I pulled out of the vinyl hose, screwed it onto the other connector that was still attached to the PEX (teflon tape on both), slipped the barbed end back in the vinyl hose, one small hose clamp and done!
Now I have a lot less volume to the plumbing system (won't take so much antifreeze) and don't have to take off the canister to drain the lines between trips. No worries about it freezing/cracking/unscrewing and the carbon filters for the external filter I already had lying around are 1/3 the price of the KW-1.
Anybody wanna buy a complete FR1 filter unit with bracket, canister wrench and unused (still in shrink-wrap) KW-1 cartridge?
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 06-30-2015, 07:28 PM   #19
Ford Idaho's Avatar
Old 06-30-2015, 08:14 PM   #20
Originally Posted by Ford Idaho View Post
I'd buy that for a dollar!
SOLD! But for you, you have to come pick it up!
