Old 06-29-2015, 03:06 PM   #1
Regrets, or why didn't I listen to you guys?
Got set up last weekend. Everything good but faucet sputtered with no water pressure. Went around back to check the pump. Opened the door to find water spraying everywhere. Filter housing had split. Shut off pump, removed filter, cut lines, made short trip to nearest town. Ace Hardware had Sharkbite connector. Made connection and all was good. Should have listened to all the good advice on this forum and made the change at home, not in the field. By the way, why is FR still using these things?
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is offline   Reply With Quote
Old 06-29-2015, 03:21 PM   #2
Georgia Frog Rally 2018
aceinspp's Avatar
Just so you would have something to do. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 06-29-2015, 03:22 PM   #3
Ford Idaho's Avatar
Shop Whirlpool 10-in Under Sink Complete Filtration System at Lowes.com
RV Exterior Canister Water Filter Stand
Old 06-29-2015, 04:50 PM   #4
RooVader's Avatar
Your miserable situation will hopefully get the point through my thick skull to actually tackle this project. Sorry, but thank you.
XLR 24HFS -> Roo 21DK -> RPod 183g
2013 F150 FX4 EB
RooVader is offline   Reply With Quote
Old 06-29-2015, 05:09 PM   #5
Cyber Phrenologist
Radio's Avatar
Could you please post some pics?
My filter canister (in the same cabinet as my water pump and water heater) is of a heavy plastic (no, really, the thing weighs a couple pounds even empty) It is beyond me how this thing could split open. But my trailer is a 2008/9 and maybe something has changed.
What, if anything, happened to cause yours to fail? Or was it just poorly made?
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 06-29-2015, 05:23 PM   #6
Sorry, no pics available. I pitched the offending piece at the campground. To clarify, the canister didn't shatter. Sorry if I gave that impression. It had a hairline crack running vertically. It was enough that when the system was pressurized by the pump , water sprayed all over the compartment. The fix wasn't difficult since the lines are flexible pex tubing and there was enough slack to make it work.
Jim and Deb
2013 Ram 1500
Old 06-29-2015, 05:48 PM   #7
TURBS's Avatar
Yours is old enough that it most likely doesn't have the crapper there putting in the new models that takes a filter that only fr has iirc.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
Old 06-30-2015, 08:52 AM   #8
Cyber Phrenologist
Radio's Avatar
TURBS
2011 32bhok Sabre
Kinda what I figured.
KU4OJ
Old 06-30-2015, 09:19 AM   #9
vinmaker's Avatar
Glad you were able to get it fixed quickly.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 06-30-2015, 09:52 AM   #10
urocav2001's Avatar
My new 16 has a smaller diameter plastic container and it is notched on the top where you screw it in. You really have to put the tool on it to get it to turn and bump over those notches, hopefully this was forest rivers way of fixing it...
urocav2001 is offline   Reply With Quote
