Originally Posted by capt104
Has anyone else had problems with A/C freezing up. My Coachmen Freedom has had this problem on and off since day one Jan 2016
Some causes in no particular order:
1, The anti-icing sensor may have moved and isn't in the proper position.
2. If it's ducted, the factory may not have opened up the passages from the cold air plenum into the ducts large enough, so your airflow is reduced, which can lead to freezing. See post #5 here to see my issue with this:
http://www.forestriverforums.com/for...ts-135238.html
3. You're running your fan on low, which will exasperate #1 and #2.
2011 Traverse LT, 3.6L, FWD
