Old 05-31-2016, 02:27 PM   #11
jeff64's Avatar
That Barker Hi-Torque with the ball screw drive is a pretty good one too. I took it off the last TT when I traded for this one. I figured when the LCI went to heck it would be a piece of cake to switch out and not have to lay out any additional $
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 05-31-2016, 09:53 PM   #12
Have a 3500lb Bulldog. Replaced it two years ago because the original one collected water ( we live in the Vancouver BC area). This one, I cover in the winter by cutting the bottom off a 4L antifreeze jug and pushing it over the top of the Jack. A little duct tape and water proof for the winter storage. Ours gets lot of use ....over 100 notes last year and most of them unhooking. Always make sure you have plenty of battery voltage or you will fry it prematurely.
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2013 22 nights.2014 57 nights.2015 116 nights
2016. 96 nights 2017 72 nights.
Filterman is offline   Reply With Quote
Old 06-03-2016, 11:30 PM   #13
dmdomokos's Avatar
I replaced the Lippert 3500 with the Bulldog 3500. The BullDog is shorter, which helps with my Suburban liftgate clearance.
2016 Rockwood 2702WS
2016 Chevy 2500HD Duramax 4x4 High Country
dmdomokos is offline   Reply With Quote
Old 06-03-2016, 11:43 PM   #14
asquared's Avatar
Installed the ultrafab tongue Jack on our old TT. Had it on the tt for almost 3 yrs. It was still going strong when we sold the tt.
You need to measure your opening so you get the correct size. If the bolts don't fit the existing holes, just turn the Jack sideways or backward.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 06-04-2016, 12:21 AM   #15
Professional Curmudgeon
Originally Posted by cpd1343 View Post
Husky 87641 Brute Electric Jack with Wireless Remote - 4500 lbs. Capacity
Robot Check
This is my next purchase. With a back up camera it only makes sense to be able to raise and lower from inside the truck!
2002 Forest River Flagstaff 8528RLS
2014 Coachmen Catalina 253RKS
2016 Keystone Summerland Mini 1750RD
2012 F250 Lariat 6.2L Crew Cab FX4
wrvond is offline   Reply With Quote
power, replacement
