Old 10-19-2016, 05:06 PM   #1
Replacement Stabilizer Jack 2015 ROO 21SS
Due to an episode of dumbassery, I'm now in the market for a new right-front scissors-type stabilizer jack on our camper. And I can't find anything on the jack or in my paperwork that indicates who the manufacturer is.
Can anyone give me the name of the manufacturer, or recommend a suitable replacement? From the jacks I've seen online, the attachment plates look like they're drilled to fit just about any trailer on the market. Has anyone had problems fitting one onto a ROO? Thanks!
Ajax is offline   Reply With Quote
Old 10-19-2016, 05:16 PM   #2
Witch Doctor's Avatar
I don't have a Roo but bent a jack on my old trailer, they are pretty generic and will fit any trailer. Look to see the gage and get a heavier one if you can since your replacing it anyway. I hated when I did it. But like anything, things happen and don't let it ruin your day Good Luck you shouldn't have a problem check etrailer out. Don't buy it from your STEALER for sure...
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-29-2018, 11:25 PM   #3
Velosprout's Avatar
Unfortunately I am now in the same situation, and think they are the BAL 24” scissors leveler, correct?
https://www.campingworld.com/bal-sci...iABEgJI2vD_BwE
Velosprout
2014 F150 SCrew 4x4 Max Tow Heavy Duty Payload 3.5 Ecoboost 6.5' bed Ingot Metallic Silver
2015 Rockwood Roo 21SS
Velosprout is offline   Reply With Quote
Old 04-29-2018, 11:29 PM   #4
Fulltime family RVer
Also not a Roo owner, but I went through a scissor jack about every 6 months with my old camper. Check the height and just buy from either Amazon or eTrailer. If you have a Camping World nearby, I saw great prices in the stores occasionally.
Old 04-30-2018, 06:54 AM   #5
bareftn's Avatar
Why did you go through one every 6 months?
bareftn is online now   Reply With Quote
Old 04-30-2018, 11:11 AM   #6
Anger issues, mostly. Whenever I'd get mad, I'd get the crank out and would just raise and lower them. Apparently super speed makes them melt.
Nah, my fifth wheel ran nose high once I switched to the Trail Air/Tri Glide pin box. I raised it up and lowered my hitch and still was slightly nose high.
I seemed to bend them all to crap about every 6 months on a parking lot entrance, campground entrance, or once - in the dirt at a fairgrounds because I couldn't see in my mirror because someone was standing/riding on my running boards from the check-in to my spot.
Old 04-30-2018, 12:23 PM   #7
They say if you approach it at an angel you wont bottom out,A Full timer like you Should practice that?
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-30-2018, 12:30 PM   #8
Lootraiders's Avatar
Ditto. I did it to my roo roughing it. I managed to bang it back in place and now when I take the drill to it, it wobbles down and up but still functional.
Lootraiders is offline   Reply With Quote
Old 04-30-2018, 06:42 PM   #9
Velosprout's Avatar
I wouldn’t want a stronger one; the idea is for the scissor jack to sacrifice itself and not bend or twist the trailer frame.
Velosprout
Old 04-30-2018, 07:11 PM   #10
Its not the jack its the bolts that should sacrifice, alot cheaper.
Coachmen M/H
Concord
2018 / 300 DSC
replacement, roo
