Old 05-23-2014, 11:01 PM   #1
Canadian Member
itat's Avatar
Replacing Pinch Welt on Roo Bunk Doors
Has anyone ever replaced theirs? How did you remove the old pinch welt seal and secure the new one?
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 05-26-2014, 06:45 PM   #2
imflyn2's Avatar
Dealer replaced our front bunk seal soon after purchase. They gave me enough to do the rear if ever needed. The old pulled off with a little effort and the new went on the same.
2012 23SS
2013 F150 5.0L supercrew 3.73 w/tow pkg
imflyn2 is offline   Reply With Quote
Old 05-29-2014, 07:04 PM   #3
FourWheelers's Avatar
Hello.
I've been through the process of replacing the pinch welt. I had leaking issues with the bunk ends of my 2010 Rockwood Roo 233S. I still feel it was a design flaw that was corrected in later models but don't hold any hope for Forest River upgrading the bunks.
At first I noticed the pinch welt seemed to be on wrong. The top did not overlap the sides to prevent water going down behind the side pinch welt.
Name:	ImageUploadedByForest River Forums1401407052.728141.jpg
I also noted the frame screws for the bunk ends were protruding up and positioned along the pinch welt. This prevents a tight seal.
Name:	ImageUploadedByForest River Forums1401407172.410454.jpg
I ordered the welt from Forest River direct. The old welt pulls right off and the new presses right on. You could put a sealer or gasket glue on it but I haven't seen the need. I did make sure the new top welt overlaps the sides and used silicone sealant on the corners. I replaced the existing frame screws with flat head stainless steel and used 4200 boat sealant in each hole.
Name:	ImageUploadedByForest River Forums1401407625.155704.jpg
Name:	ImageUploadedByForest River Forums1401407752.352647.jpg
I also noticed the black rubber gasket was loose so I removed that and re-glued with that yellow gasket glue.
I replaced the black pads under the door latch hoping for a tighter seal. After a month the pads retain their shape so I don't think it helped much.
After all this, I still had leaks. Using a hose you could see the water running down the inside. I did some more searching and found a fix by another member. They made a PVC device that prevents water from reaching the top of the bunk ends. I built the same and it has solved my problem. My trailer was covered this winter but uncovered in the spring and has sat during numerous rain storms. The mattress have remained dry with no sign of water.
Name:	ImageUploadedByForest River Forums1401408183.507551.jpg
ID:	53758Click image for larger version
Name:	ImageUploadedByForest River Forums1401408207.774356.jpg
FourWheelers is offline   Reply With Quote
Old 05-29-2014, 09:14 PM   #4
Canadian Member
itat's Avatar
Thanks, FourWheelers. I have exactly the same problem with the screw heads in the bed door frame.
Old 05-29-2014, 09:23 PM   #5
I also added a rain gutter above the side bunk to hold the Pipe. For some reason Forest River failed to put a gutter to keep water away from the bunk end seal.
Old 06-14-2014, 07:20 AM   #6
Itat: I could not figure out how to send the photos in message, so I thought I would post them.
Name:	ImageUploadedByForest River Forums1402748393.564086.jpg
Name:	ImageUploadedByForest River Forums1402748410.551475.jpg
Name:	ImageUploadedByForest River Forums1402748424.322213.jpg
Hope this helps.
Old 06-14-2014, 07:58 AM   #7
Canadian Member
itat's Avatar
Thanks, FourWheelers!
Old 06-14-2014, 08:20 AM   #8
Canadian Member
itat's Avatar
FourWheelers did you use two 10' lengths of 2" SCH 40 PVC pipe like pixleys did in this thread?
Bunk end water fix...cheap!
I tried to use a foam rubber weatherstripping over the frame screws but I can't find anything thin enough. I need something about 1/8" x 1-1/4" to work.
Old 06-14-2014, 05:00 PM   #9
Itat: I needed three lengths of 2" PVC. I attached another rain gutter over my third bunk.
As for the weather stripping, I didn't use any over the frame screws. I replaced the screws with stainless steel using white marine caulk in the holes. There is still a slight gap between the pinch welt at the top but this pipe device prevents any water from getting on the seal and leaking through.
Old 06-14-2014, 05:48 PM   #10
Canadian Member
itat's Avatar
I've been told by 2 people that in order to get the door frame screws more square I should drill out the screw holes a bit to accept screws one size larger and replace the stock screws with bigger screws. Did you have to do that? Obviously you have the same issue with the frame screws not being drilled square to the frame.
door, roo
