Old 09-01-2014, 07:14 AM   #1
Replacing the canvas in a Roo
Hi. Just wondering if anyone has ever removed the end tents on a Roo camper? If so is there any tricks to getting them back in the channels that hold them to the camper frame? Thanks.
Robe is offline   Reply With Quote
Old 04-01-2015, 11:27 PM   #2
jpgowin's Avatar
Name:   ImageUploadedByForest River Forums1427948762.112586.jpg
First remove the screw near the bottom of the side metal frame that secures the tent end
Sent from Johns iPad using Forest River Forums
2021 Coachman FE 257BHS
2014 Nissan Armada
Papa & Nana, 5 daughters & 5 grandkids.
Former RV’s: 2009 Rockwood Roo 23ss, 1999 Coleman Niagara, 1978 Apache Popup
jpgowin is offline   Reply With Quote
Old 04-01-2015, 11:46 PM   #3
jpgowin's Avatar
Name:   ImageUploadedByForest River Forums1427949345.174066.jpg
Start pulling the rubber tent edge seal with firm pressure
Name:   ImageUploadedByForest River Forums1427949447.945914.jpg
Name:   ImageUploadedByForest River Forums1427949483.064644.jpg
Pull out seal all the way towards top of bunk end frame
Name:   ImageUploadedByForest River Forums1427949587.110504.jpg
Once tent ends are removed, carefully remove old silicone without ripping the black rubber seals
Name:   ImageUploadedByForest River Forums1427949695.573530.jpg
Continue to remove top tent edge seal after both sides have been removed
Name:   ImageUploadedByForest River Forums1427949854.248463.jpg
Beginning of job from outside
Name:   ImageUploadedByForest River Forums1427949905.059354.jpg
Both sides removed from outside
Name:   ImageUploadedByForest River Forums1427949956.168043.jpg
Totally removed
2014 Nissan Armada
Old 04-01-2015, 11:57 PM   #4
jpgowin's Avatar
CANVAS REPLACEMENTS
Name:   ImageUploadedByForest River Forums1427950633.996490.jpg
http://www.canvasreplacements.com
Contact: Lorin Rigby
This company does top quality work, was very easy to work with and was the only ones willing to include vinyl windows on my new tent ends. Regular bunk end replacement with screens average around $900/ pair. My set cost $1,300 which included vinyl windows, three per bunk end. Pricey but well worth it.
2014 Nissan Armada
Old 04-02-2015, 12:17 AM   #5
jpgowin's Avatar
START OF INSTALL
Name:   ImageUploadedByForest River Forums1427950733.820057.jpg
Tools needed for reinstall, (home made wood push stick)
Name:   ImageUploadedByForest River Forums1427950823.954178.jpg
Silicone sealant used, cleanup with minimal spirits
Name:   ImageUploadedByForest River Forums1427950894.239416.jpg
Unbox new tent ends, check to see all end seals are unfolded
Name:   ImageUploadedByForest River Forums1427951062.031256.jpg
Verifying all zippers work and vinyl windows are ok
Name:   ImageUploadedByForest River Forums1427951139.621160.jpg
Closeup of vinyl windows
Name:   ImageUploadedByForest River Forums1427951199.750011.jpg
Closeup of screening material
Name:   ImageUploadedByForest River Forums1427951239.417347.jpg
Closeup of edge seal details
Name:   ImageUploadedByForest River Forums1427951297.744288.jpg
Verify that all old silicone seals are removed
Apply new bead of silicone between black rubber seal and metal frame track
Name:   ImageUploadedByForest River Forums1427951355.150173.jpg
Clamp top edge to gutter rail, leave off last two clamps on one end to allow slack to start installing seal in frame track
Name:   ImageUploadedByForest River Forums1427951536.588609.jpg
Use wood push stick to insert rubber "bead" into track
Name:   ImageUploadedByForest River Forums1427951723.953131.jpg
Apply generous amount of silicone on outside of tent and black seal
2014 Nissan Armada
Old 04-02-2015, 12:26 AM   #6
jpgowin's Avatar
Name:   ImageUploadedByForest River Forums1427951868.142225.jpg
Smooth out bead of silicone with gloved finger, wipe off excess being careful to not get excess on black seal to prevent bunk closure
Name:   ImageUploadedByForest River Forums1427952027.904743.jpg
Apply excess silicone on corners
Name:   ImageUploadedByForest River Forums1427952092.924677.jpg
Start installing either side tent bead, then opposite side
Name:   ImageUploadedByForest River Forums1427952154.767252.jpg
Apply outside silicone once sides are installed then smooth out
Name:   ImageUploadedByForest River Forums1427952222.900317.jpg
Secure bottom of side bead on each side, reinstall original screws to lockin tent bead
Name:   ImageUploadedByForest River Forums1427952339.105030.jpg
Finished Bunkend with vinyl window installed
2014 Nissan Armada
Old 04-02-2015, 02:57 PM   #7
very nice...I often wondered why pups and hybrids don't have vinyl on the bunk ends.
2014 Rockwood Roo 23IKSS
2012 Dodge Ram 1500 Hemi 4X4
Me, Hubby and Luna the Lab
sewingcybermom is offline   Reply With Quote
Old 04-02-2015, 03:40 PM   #8
bikendan's Avatar
it may have to do with the ends being fire exits.
Old 04-02-2015, 07:05 PM   #9
jpgowin's Avatar
DW and I just wanted to have the option of having the windows open without loosing the cold air when A/C is on in summer and lose of warm air during cold weather. I think you're right about the emergency exit limitation.
2014 Nissan Armada
Old 04-02-2015, 07:34 PM   #10
geotex1's Avatar
If needed, I have a brand new factory tent set still up for sale that fits Roos/Shamrocks A HECK OF A LOT CHEAPER than you can lay hands on anywhere else! See the classifieds or PM me.
geotex1 is offline   Reply With Quote
Old 04-02-2015, 10:09 PM   #11
I covet your windows terribly but am not ready to fork over that much money when my tents are still perfectly good.
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
chriscowles is offline   Reply With Quote
Old 04-02-2015, 10:14 PM   #12
When I came home from my last trip I found one upper corner pulled about 3" away from the groove. I took it to Camping World for repair under warranty, which they did. But, from the sound of things I'm not sure they put much effort into it. Something to the effect of "pushed back into channel, applied extra sealant".
I haven't had a chance to evaluate that work. If it looks jury-rigged, do I need to consider taking it apart and doing it myself? There's nothing wrong with the material or seams.
Old 04-30-2018, 08:25 PM   #13
I know this is an old post, but can you post a picture of the push stick so i can make my own?
My visions is poor and I can't make out the dimensions to make my own.
RichMolumby is offline   Reply With Quote
Old 04-30-2018, 11:06 PM   #14
bikendan's Avatar
Rich, the OP hasn't posted on the Forum in almost 2 years now.
I suggest you PM the OP and see if they answer.
Do you own a hybrid?
By the way, the OP posted a clear pic of the push stick in post #5.
You could the other items in the pic to get a good idea of the dimensions.
roo
