Old 06-05-2012, 10:51 AM   #1
RoadDog66's Avatar
Rim measurement
Ok this may be a dumb question, but here goes. I finally received my extra HWT Series 06 rim (w/no tire). It looked big so I measured the diameter and it was 15-5/16" from edge to edge. This concerned me since it's supposed to be a 14" rim.
The paperwork says 14" rim too, but since I've had issues getting the correct rim I wanted to be sure. Just to verify it was the correct rim I drove over to my Roo and since my other rims are mounted on the trailer I could only make the same edge to edge measurement and it was the same (15-5/16").
Now the tire size listed on the tires is ST205/75/R14 (which tells me it's a 14" rim size). Anyone know why a 14" rim actually has a 15" diameter?
Name:	Roo Wheels-Tires 3.jpg
ID:	14822   Click image for larger version
Name:	Roo Wheels-Tires 2.jpg
ID:	14823   Click image for larger version
Name:	Roo Wheels-Tires 1.jpg
TV: '15 Ram 6.4 Hemi CC 4x4
Old TT: '12 Rockwood Roo 19 (sold)
New TT: '14 CR Sunset Trail 290QB
WD: Equalizer 1200/12K
BC: Ram OEM
RoadDog66 is offline   Reply With Quote
Old 06-05-2012, 10:56 AM   #2
Missing Link
cyclepuck's Avatar
You have to measure the rim where the tire bead sits. Not the outside dia.
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
cyclepuck is offline   Reply With Quote
Old 06-05-2012, 10:58 AM   #3
You are measuring the flange, not the surface the tire actually seats on. The ID of the tire will be very close to 14" as will the surface of the rim that the ID of the tire sets on. The flange is what actually holds the tire on the rim. The flange will measure 0.656" (just over 5/8") deep all the way around the rim.
Old 06-05-2012, 10:58 AM   #4
Missing Link
cyclepuck's Avatar
Here
2014 Puma 30-DBSS
Old 06-05-2012, 11:22 AM   #5
RoadDog66's Avatar
Ok thanx guys. That makes much more sense now. I've never gone and measured a rim before so it confused me and I didn't want to have to suffer another another 4 months of emails & phone calls to get another rim.
I appreciate the info.
BC: Ram OEM
