Old 04-09-2015, 12:48 PM   #1
wicked1's Avatar
Rockwood Roo 23IKSS Questions
I have not been able to find these anywhere but does anyone know the following, FR site for the Roo does not indicate these.
1) Size of the Refrig/Freezer 6.3 or 8.0? Brand?
2) AC Brand, I think they are Dometic, but does anyone know if they come with the new Digital Thermastat, if not how hard are they to put in?
3) Brand of Water Filter it will use, the sales person at the dealer says he doesn't know and said wait until Saturday to pick mine up
4) Size of the tires? Mine has Aluminum wheels
5) I think the new 6 gal HWHeaters are gas/electric/dsi Attwood's which I hope they are still using I do not like my 6 Suburban in my trade in trailer, hate the anode rods
Thanks in Advance and sorry if this info seems to be repeated, I just can not find this info anywhere.
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 04-09-2015, 01:23 PM   #2
deartruc's Avatar
Caught me 30 miles away from my camper but this I can tell you. Mine is the first half 2015. The water heater has the electric switch outside beside the heater access panel. (previous htt was on the inside management panel). Also, the anode rod is part of the drain plug. Nice feature since you pull the plug to winterize and can see what life is left. My fridge has no digital controls. Gas only or electric/gas. The temp control is a bar on the cooling fins you slide up and down.
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 04-09-2015, 01:25 PM   #3
Dometic size may depend on if you have a separate door on the freezer.
They typically have a analog thermostat. I replaced mine with a digital.
Water Pur. cartridges are about $30. Many have replaced theirs.
14" I am not sure about the rest of the size.
Sorry, its a Suburban!
See above
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is offline   Reply With Quote
Old 04-09-2015, 01:38 PM   #4
deartruc's Avatar
A/C is managed by the trailers heat and a/c thermostat. Kind of a disadvantage when you want to run both heat and a/c at the same time (like when you're trying to lower the humidity because condensation is building up). I just bought a portable dehumidifier and our icebreaker voyage is next week. I will find out if it can handle the condensation.
2017 GMC Yukon
2015 Roo 23 ikss
Old 04-09-2015, 01:45 PM   #5
wicked1's Avatar
Originally Posted by Archicamper View Post
See above
Really they went to Suburban HWHeaters? argh, I think the attwood's are so much better because you do not need an anode rod, ugh.
I wonder if they make all of them with Suburban now, or if it is like the auto industry, if the lot they buy at the time is cheaper they go with one or the other. I really hope my new 2015 is not a suburban, but thanks.
Old 04-09-2015, 01:54 PM   #6
deartruc's Avatar
I think the Attwood's require a rod too. It's just nobody ever take it out to look at it.
2017 GMC Yukon
2015 Roo 23 ikss
Old 04-09-2015, 02:08 PM   #7
deartruc's Avatar
Stand corrected. Attwoods don't require a anode rod. They build thicker tanks which act like the anode rod to slowly get eaten away. Probably why I never had to replace the rod in my 2010 starcraft htt.
2017 GMC Yukon
2015 Roo 23 ikss
Old 04-09-2015, 02:13 PM   #8
wicked1's Avatar
I thought it was because attwoods are aluminum and steel for suburban, a buddy has a 2006 Fleetwood Bounder with an attwood, he put an anode rod in his attwood and it fused itself to the tank, the dealer could not remove it, had to replace his tank?
Old 04-09-2015, 02:14 PM   #9
I have a 2014 23Ikss...it is definitely a suburban WH with the anode.
A/C does not have a digital thermostat.
I'll check the fridge and tires for you, as they have not changed for 2015
2014 Rockwood Roo 23IKSS
2012 Dodge Ram 1500 Hemi 4X4
Me, Hubby and Luna the Lab
sewingcybermom is offline   Reply With Quote
Old 04-09-2015, 02:32 PM   #10
bikendan's Avatar
Roos/Shamrocks have always had Suburban WHs, as far as i remember.
have never heard of them having Atwoods, even with the first ones in 1999.
unless things have changed, you'll get an analog thermostat that's worthless. most change it out for a digital one, Hunter or Honeywell.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
rockwood, rockwood roo, roo
