Old 04-11-2016, 02:11 PM   #1
Roo 19 hitching tips/tricks
I'm a new Roo owner, the handful of times I've hitched up I've had a heck of a time getting the latch to close on the ball, usually having to subscribe to blunt force....is there a trick to this style of trailer hitch?
2015 Roo 19
Equalizer 600/6000
2 5/16 equalizer brand ball
2007 Silver-Ray-doh
Sent from my SM-G900P using Tapatalk
jehrbear is offline   Reply With Quote
Old 04-11-2016, 02:13 PM   #2
To be specific, the trouble is when I attempt to lock the hitch onto the ball. Disconnect is stiff but not nearly as painful.
Thanks in advance,
Old 04-11-2016, 02:21 PM   #3
JustB_Rad's Avatar
get in the TV and put it in nuetral to let it roll just slightly forward (unless you're going uphill, then use drive) just until the ball hits the front of the coupler and it should go down very easily.
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
JustB_Rad is offline   Reply With Quote
Old 04-11-2016, 03:26 PM   #4
Good tip, I'll try that, although I probably need to find the manual too, see if there's an adjustment, or it needs grease (or since its new, just a rough break in period).
Old 04-11-2016, 03:35 PM   #5
bikendan's Avatar
Most common reason for your issue, is the ball is too far back in the coupler.
As was suggested, let the TV roll forward so the ball is as forward in the coupler as possible.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-11-2016, 04:40 PM   #6
No need to grease the ball. If the latch mechanism itself is still stiff , suggest you spray with a lube . I use Slick 50. Better than WD 40 and not as oily. Not much residue.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is offline   Reply With Quote
Old 04-11-2016, 04:44 PM   #7
Hopefully this diagram helps. You need to have the ball as far forward as possible for the latch to go down.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=2
Electra glide is offline   Reply With Quote
Old 04-12-2016, 10:37 AM   #8
urocav2001's Avatar
I have my coupler angled forward just a little bit, comes on and off nicely, occasionally I'll have to drive forward a bit to get it to come off after backing
urocav2001 is offline   Reply With Quote
Old 04-12-2016, 11:49 AM   #9
Hitch
I agree, let the TV roll forward. But I also greased the hitch ball and that improved the smoothness of closing the latch.
TheGreatWaz00 is offline   Reply With Quote
Old 04-12-2016, 12:41 PM   #10
rsdata's Avatar
when backing up to latch have your helper stop you just a quarter inch forward from being under the ball coupler... when you let the coupler down, the trailer will move forward to drop on the ball that 1/4 inch and the latch will work easily... make sure you remove your FORWARD facing wheel chocks to let the camper pull forward that 1/4 inch
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
hitch, roo
