01-23-2016, 10:00 PM
Roo 19 Thermostat Replacement
Looking for recommendations to replace my Roo 19 furnace thermostat with a digital one. I need a very basic one for the furnace only (air conditioner is not connected to thermostat). Don't need adjustable fan speeds but want something that has a thermostat swing of a couple of degrees so the furnace doesn't cycle too often. Thanks in advance for any advice. Fly Navy!
2016 Roo19 Hybrid
2015 GMC Sierra 4x4 Crew Cab
01-23-2016, 10:11 PM
01-24-2016, 11:19 AM
2011 Traverse LT, 3.6L, FWD
01-26-2016, 03:03 PM
I used a Hunter for my Roo 19. Search for Hunter thermostats, lots of information out there but it was a matter of just switching the wires.
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
01-27-2016, 12:39 PM
Dahagen
I too used the hunter shown. Quick and easy.
01-27-2016, 09:19 PM
I'm sure the Hunters are fine. I went with a LuxPro010BF (Amazon, $30) for the very reason you state: I wanted digital preciseness to calm my furnace down. That's all it is, a digital thermostat replacement for the analog version provided by the factory. 2 wires off the old one and reconnected to the new one. I only went with the Lux brand because of my experience with my Lux thermostat in my home, going on 20 years now.
03-12-2016, 01:03 AM
UPDATE: I ended up purchasing the Honeywell RTH 2300/RTH221 series thermostat from Target for about 23 bucks. Works much better than the OEM thermostat that came with the Roo. Just hook up the two wires coming out of the camper to the thermostat's R and W connectors. Doesn't matter which camper wire goes to which R & W thermostat connection. Works like a champ controlling my heater.
2016 Roo19 Hybrid
03-12-2016, 09:10 AM
03-13-2016, 05:45 AM
Will that work also in a 23ss??
03-13-2016, 06:03 AM
Years ago, I replaced the analogue thermostat in our old hybrid (after we had owned it for several months) with a digital White/Rodgers just to see if it would give us better control and reduce the "I'm hot" / "I'm cold" comments. Best mod I ever did and the very first one I did with our new trailer Highly recommend this mod to all!!!
2010 Wildwood XLite 26BHXL
2013 Ram Outdoorsman 5.7l
03-13-2016, 07:48 AM
the Roo/Shamrock 19 has NON-ducted a/c. so their thermostat is for heating only.
your 23SS has ducted a/c, so a digital thermostat will control heat AND a/c.
i installed a Honeywell digital thermostat on my 23SS. works great except i didn't set up the fan speed. i just have it connected to the LOW setting for a/c.
03-15-2016, 05:50 PM
I installed a switch on my 23IKSS to control the fan speed. The instruction are here:
