Old 03-26-2014, 07:59 PM   #1
Roo 233S door question
Do you know if you remove the spring arm on the bottom of the door will it open all the back flesh w/ the camper? Seems like a bad design having the door sticking out (kids running into it or wind catching it).
Just wondering if anyone has tried making it go all the way back.
ParrishCamper is offline   Reply With Quote
Old 03-27-2014, 08:23 AM   #2
KMP44's Avatar
No, it won't open flush because of the awning. If the awning is out, it won't go more than a couple inches farther than it goes now. If the awning were rolled up, it would go farther, but still hit the arm that is against the side of the trailer.
I thought this was a terrible design at first too. Growing up my parents had a MH and a couple trailers - all of them had doors that opened all the way and you latched them to the side of the rv. But, after having the Roo for a while, I like this setup on the door. And the gas spring that holds it works really well. There aren't any sharp corners and even with a crowd and lots of kids running around, it seems to be fine.
Edit: Actually since you have the 233S the door is in the middle so it might go all the way flush. Most of the other floorplans have the door at one end of the awning...
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 03-27-2014, 05:08 PM   #3
rbq
Our 233S is pre strut so it opens all of the way & we have the little white plastic arm to hold the door open. Even with the awning out there is no problem with the door hitting the awning.
2001 Chevy Silverado
2011 Rockwood Roo 233S
rbq is offline   Reply With Quote
233, 233s, door, roo
