Roo 233S plumbing/winterizing help
Good Morning Everyone,
Looking for the Roo 233S owners....just received delivery of our 2011 233S. We previously owned a 2006 Roo 233, but it was totaled this past Winter/Spring with a roof collapse. I just walked through locating all the needed plumbing/appliances and their valves for winterizing, this coming fall. I also just thumbed through the manuals...and had a few questions regarding winterizing.
Looks like the low point drains are located under the passenger side rear of TT, below shower area? Is this correct?
Up near the water heater, I see a hot and cold hose that runs down into the floor, but outside under the TT, I see a drain..Does that drain just clear out the line between the FW tank and the pump?
Also it looks like they got rid of the small T valves on the plumbing and went with hose caps.....is this correct? Or are there valves located inside the TT? Any insight is greatly appreciated! Looking for or going to try to create a winterizing walkthrough for the 233S. All the Manu. manuals are so general. Just trying ot understand the plumbing, so I am not guessing in the fall. I did the witerizing on our 233, but items and valves have all changed looks and locations....Thanks
