Old 04-08-2015, 11:14 AM   #1
Roo 23Ikss
Is there a water filter somewhere on my camper? I don't see one in the obvious places.
When I figure this all out, I swear I'm gonna create a video library for every thing I do. It's got to help someone.
2014 Rockwood Roo 23IKSS
2012 Dodge Ram 1500 Hemi 4X4
Me, Hubby and Luna the Lab
sewingcybermom is offline   Reply With Quote
Old 04-08-2015, 11:18 AM   #2
offroad's Avatar
Probably near the water pump, and perhaps behind a door that looks like it should open but has been fastened shut with a hinge where you'd expect a handle.
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 04-08-2015, 11:23 AM   #3
Go through the rear outside access door and remove the panel inside. That will give you access to the filter and the water heater.
Nccamper is offline   Reply With Quote
Old 04-08-2015, 11:28 AM   #4
rear as in next to the spare tire?
Old 04-08-2015, 11:49 AM   #5
Hicks43's Avatar
Mines in the front left side. 21ss shamrock.
Hicks43 is offline   Reply With Quote
Old 04-08-2015, 12:08 PM   #6
Old Ram Guy
Avenger61's Avatar
That's right, rear as in next to spare tire. In that compartment will be a divider panel you will need to remove and the water filter is mounted directly behind that panel. You should also have a plastic water filter wrench that will remove the filter canister.
Marty, Jenice and DD
Avenger61 is offline   Reply With Quote
Old 04-08-2015, 12:19 PM   #7
X2
Old 04-08-2015, 01:23 PM   #8
wicked1's Avatar
can you bypass this water filter for winterizing it? I know I have seen videos where they say fill the empty clear container with antifreeze, but here in NJ some of my antifreeze froze with the cold winter, so do not want to see that happen, prefer to bypass it winterize it, and leave the clear canister on but empty. What a pain in the neck place to put that, should have been under the bathroom or kitchen sink IMO
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 04-08-2015, 01:54 PM   #9
Old Ram Guy
Avenger61's Avatar
I'm sure there is a way to put in a couple pieces of pex and some bypass valves to get around it. I didn't like the location at all and I heard too many horror stories about those canister filters vibrating loose and leaking, so I'm taking mine out. I intend to find a place for it outside the trailer and I'm not sure I'm even going to use the same canister filter either.
Old 04-08-2015, 01:59 PM   #10
I put an empty water bottle in mine to minimize the amount of antifreeze in the canister.
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is offline   Reply With Quote
roo
