Old 06-05-2013, 03:46 PM   #11
Kaytee1206's Avatar
Originally Posted by HONDAMAN174 View Post
Excellent. Thank you. Can you find out if you are using the 4" bracket or the 6"? Thanks again
We have the 4 inch. We checked into it and were told we would only need the 6 inch if we had our truck lifted, which we don't.
2013 Rockwood Roo 25RS
Kaytee1206 is offline   Reply With Quote
Old 06-05-2013, 04:06 PM   #12
HONDAMAN174's Avatar
Great and tgakns
Just glad to get away
Old 06-05-2013, 04:06 PM   #13
Wow. Thanks
Old 06-06-2013, 07:05 PM   #14
Hondaman174,
We have the 23ikss and have the same WDH as you and have and so far towed twice, works great. I have not installed the sway control yet, didn’t have time at first and it’s pulled great without it. Our TV is a 2006 F150 super crew with the 5.4 triton. I went with that WDH because all the other $$ we were throwing at the trailer to get ready just couldn’t swing the $400 + for the other models but so far I’m happy with it. I’ll update at the end of the summer after we’ve had a few more trips under our belt.
stardrive is offline   Reply With Quote
Old 06-06-2013, 07:12 PM   #15
Well this is all informational right now. Just listening to everyone's setup and seeing what works and what works really well for some. Still beating up dealers on pricing (and talking DW into it). I do like that Anderson WDH though- looks like I can't even mess that up!
Old 06-07-2013, 09:59 AM   #16
cogito ergo moo
Cowracer's Avatar
All the hitches listed are great, but I am partial to my Reese Dual-Cam. Absolutly dead solid sway control in all conditions. No friciton material to wear out. Some people say they are noisy, but the only time I ever hear any noise is when I am backing up and have a huge angle on the hitch (like when trying to line up in the campsite). Even then its just a light 'thunk' once in a while.
tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 06-07-2013, 08:24 PM   #17
If you're seriously considering an Anderson WDH, google Anderson hitches and add "review." The Airstream guys were discussing some issues they were having with the Anderson. Several guys were having the latch that locks around the ball coming undone. On a norma WDH, the spring bars tend to pull the A-frame of the hitch DOWN. On the Anderson, the springs/chains try to pull the A-frame towards the ball, which is apparently causing some to try to unlatch. There are other concerns regarding the brackets on the A-frame. Again, on a normal WDH, the srping bars are pulling down, but on the Anderson, the springs/chains are trying to pull the brackets forward. If they were to slide, you'd have an issue. There's apparently a "set screw" that's supposed to keep them from sliding, but they were questioning its adequacy. I do like the no-grease, though!
Old 06-11-2013, 10:31 PM   #18
The Andersen hitch is not compatible with the Atwood 88000 coupler due to that unlatching problem. Just look at the stamping on your camper's coupler and make sure it doesn't say Atwood model 88xxx. I just took the maiden voyage of about 400 miles with my new Andersen hitch and had no problems. Of course I never towed it without the hitch to compare, but it was easy to install and completely silent with no problems backing up.
2014 Prime Time Tracer 230FBS
2004 Dodge Ram 2500 diesel
NATURE is offline   Reply With Quote
