Old 04-29-2015, 09:24 AM   #1
wicked1's Avatar
Roo 23IKSS Rear Bunk TV Mount Question
Does anyone know where the backing mount points are on the rear Bunk Wall opposite the Bathroom Shower. I want to Mount a TV and there is a plate that says TV Backer but I don't know where that is behind the wall? I don't want to screw thru the entire wall and need to know what Size Screws to use?
2014 Ford F-150 FX4 Crew 4X4 EB 3.5
2015 Roo 23IKSS
2015 (3) Nights Camped
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 04-29-2015, 01:16 PM   #2
Carlosrod's Avatar
Wicked
I really went back and forth about installing a TV in the kids bunk. My opinion is they should be out in the woods enjoying the outdoors. But on days with bad weather, It's a great sitter.
You don't have a lot of room on the backer, so you need to be careful. The "Backer" is about 5 inches to each side from center and about 6 inches top and bottom from center.
I installed a small TV and used 1 1/4 inch screws. Unless you are installing a 55 inch flat panel, that should suffice.
I would use the smallest mount you can find. I used a $19.00 mount I was able to find at Micro Center. I'm sure amazon has a small one as well.
Picture of Mount
And TV. This bunk is used by my son and daughter, so this size is just perfect for them.
Hope that helps, but I'm sure others will have additional info to add and always welcomed.
Remember, if you go thru the wall, at least you'll have a place to hang your towel in the center of the shower.
Happy Camping.
Live, so that when your children hear the words Ethics, Trust, Integrity and Honor, they think of YOU!
2015 Shamrock 23 IKSS Pushing a 2015 Durango R/T. Yeah, it's a Hemi
Nights Camped - 2013/17 - 2014/24 - 2015/22 - 2016/Pending
USMC - Semper Fi
Carlosrod is offline   Reply With Quote
Old 04-29-2015, 02:29 PM   #3
wicked1's Avatar
Originally Posted by Carlosrod View Post
Wicked
Picture of Mount
Happy Camping.
Ok great thanks I was going to install a 24" that I already have but I have to measure I think my bracket will be within those specs will measure before 4th of July. GF's daughter and her friend will be with us and I have the whole RV wired with an Apple Mac Mini with all our music and movies 1200+ so from either TV they can watch one movie via WiFi and we can watch a different one. I am in IT so bought the Mini so I don't have to carry the MacBook Pro bc I have a wireless Mouse and Kybd so we can even use it to look stuff up and carry a small portable USB printer. GF is always finding deals but you have to print coupons so set this up and never have to worry anymore Roo is wired to the hilt with Capacity 😜
2015 Roo 23IKSS
Old 04-30-2015, 11:40 AM   #4
husky family's Avatar
I mounted a 2nd TV in my 233s, and used a regular stud-finder to locate the plywood backer. Worked great.
2014 Rockwood Roo 233s
2014 Runaway Navigator
2013 GMC Yukon XL
husky family is offline   Reply With Quote
Old 04-30-2015, 11:59 AM   #5
wicked1's Avatar
Ah not a bad idea but do you know what size screws you used
2015 Roo 23IKSS
Old 04-30-2015, 12:16 PM   #6
2015 Roo 23IKSS
It's been a while, so I don't remember. I drilled a pilot hole to estimate the plywood depth. Maybe you can do the same.
2013 GMC Yukon XL
Old 05-16-2015, 10:57 AM   #7
Hi I mounted a mounting adj plate I got on e bay for like 34$ the factory is cheap n expensive I used a stud finder to mark the wood which is where the sticker is but u want to be exact on where the wood is the. Use screws wood ones that go like 1/2 " into wall because if they are too long u will screw right Into your shower liner mine worked great
travelguy is offline   Reply With Quote
Old 05-16-2015, 11:05 AM   #8
Use a omni swivel mount TV can buy on eBay works great for real bunk hookup
Old 05-16-2015, 11:44 AM   #9
Marines0811's Avatar
http://www.ramco-eng.com/#!extending-mounts/cf63
Factory mounts
Marines0811 is offline   Reply With Quote
Old 07-07-2015, 11:04 AM   #10
urocav2001's Avatar
Do you happen to know what size screws you used to mount the bracket?
urocav2001 is offline   Reply With Quote
mount, roo, tv mount
