Old 07-21-2015, 07:34 PM   #11
dvalley's Avatar
Thank you kennyairport and bikendan. No, the dealer did not show us, or if they did we didn't remember. I will check it out tomorrow while I am loading up the camper.
dvalley is offline   Reply With Quote
Old 08-09-2015, 07:10 PM   #12
Mine is starting to do same thing, it used to click when in all the way, now it blows fuse. First time it ever happened but thanks to this post I found the fuse. Luckily it was all the way in. I am going to have dealer still check for a short. On hot days the AC keeps tripping breaker with nothing else running.
RichSandy-NJ is offline   Reply With Quote
Old 07-10-2016, 07:28 AM   #13
Ben M's Avatar
I have a 2013 roo 233s, and when breaking camp Friday, my slide would not come back in. I was afraid it was the motor (250.00 min), I checked the fuses in the fuse panel and they were all good. After reading this, I have another place to check? I will look for the 30 amp fuse under the trailer. Thanks for the tip.
Ben M is offline   Reply With Quote
Old 07-15-2016, 09:19 PM   #14
Same for me my 2015 23ss slide worked fine for the 3 camp site on our way south. Got to our spot in the Keys and nothing. Had a moment of panic but remembered the manual crank. Checked panel but all was good. Had the same thought $$$ or time at the dealer. I have been traveling home to NJ going to have 1 or 2 stops before getting home. It's not crazy hard but seems like you just crank and crank. Glad I saw this thread and remembered seeing the fuse under there. I'll check it when I get home.
1st timer is offline   Reply With Quote
Old 07-16-2016, 05:33 AM   #15
bareftn's Avatar
Well mind did it on Friday and as we all know when you have a problem always check here first for someone else has already had the same problem and you will find the answer here most likely . Has anyone found out why it happens? The first fuse I put in blew then the second fuse now still working but I have a auto resetting fuse ready to go in and when I was at the auto parts store I bought several replacement fuses that I would need ( I hope not ) one day 7.5, 15. 20 30 40 amp.
bareftn is offline   Reply With Quote
Old 07-16-2016, 06:01 AM   #16
I used this and it really helped for a smooth travel in and out.
https://www.protectall.com/shop/slid...-lube-aerosol/
Les & Heidi Kramer
2010 GMC Sierra SLE & 2014 Shamrock 23IKSS
Cleveland, OH
cpd1343 is offline   Reply With Quote
23ss, fuse, roo, slide
