Old 06-13-2016, 01:12 PM   #1
Roo A/C
Sorry, subject was supposed to be Roo A/C. I'm on a mobile.
Hello all. We have a 2017 Roo 233s. We love it but I'm noticing the A/C isn't very forceful. Not blowing out with the fan very well. It's on high. It's about 93 degrees and we do have Pugs but just wondering about the level of air flow I'm supposed to be getting with the A/C. I've owned a Coachman and an Rpod that seemed fine.
Thanks.
Sparkyjcm is offline   Reply With Quote
Old 06-13-2016, 03:04 PM   #2
Head Rambler
There should be plenty of air flow out of the discharge on high. Have you taken the grill off and checked for obstructions?
Gotta go campin!
Old 06-13-2016, 03:58 PM   #3
bikendan's Avatar
The main vent grill overhead has a diverter tab that may be moved over.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-13-2016, 04:12 PM   #4
Mr. Dan's Avatar
Fixed it.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 06-13-2016, 05:00 PM   #5
Thanks for the replies.
The tabs are closed to bring the air through the ducts. When I open the tabs, seems to be somewhat decent flow there at the unit but not what I would hope. When closed the air out of the ducts seems so weak.
Old 06-13-2016, 05:01 PM   #6
Bama, the grill inside at the unit?
Old 06-13-2016, 05:18 PM   #7
Flybob's Avatar
It is possible that one or more of the ducts are restricted. They are sometimes smashed during the build process. Also if you start the unit on a hot humid day with the quick cool dump closed, the coils can freeze up do to reduced air flow. When it is hot and humid, I run the quick cool dump full open until the interior cools down, then gradually close it to force air into the ducts. In addition some of the ducts in your unit may be 2" dia ducts even of the actual wall vent is 4". Pop the cover off the vent and check the duct size.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-14-2016, 09:03 AM   #8
Head Rambler
Those ducts never put out as much air as we'd hope they would. If you have an inspection camera it's a good place to use it. If you don't you can take the inside grill off and use a mirror to look into the ducts to see if they're clear.
I'm sure Turbs will post his picture soon, but it could be that air is recirculating between the intake and return because of a bent air dam or incorrect installation.
Gotta go campin!
Old 06-15-2016, 05:02 PM   #9
Thanks. I'm starting to think this is normal and I have to deal with it. Don't see any obstruction. I'll have service take another look soon. They told me today that the best we can expect is a 20 degree difference (I was getting around 15 on our trip) but still not sure about the lack of flow (lack of, in my opinion).
Old 06-17-2016, 06:55 AM   #10
Dave Lyon's Avatar
FWIW, the ducts our 23SS blow hard....works great. Last summer we camped in 90 deg. weather and the A/C had no trouble cooling the trailer to 70 deg.
I'm not sure if I'm lucky with a good unit, but, I have no complaints whatsoever about the performance of the A/C.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
roo
