Old 06-04-2012, 08:50 PM   #11
bikendan's Avatar
so, you had the 7-pin pigtail from the trailer replaced?
check the above diagrams and test the connector.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-04-2012, 09:16 PM   #12
TURBS's Avatar
Originally Posted by sryan421 View Post
My TV is a 2005 Trail Blazer with a 4.2 engine, a little lite for towing. But, it did come with the towing package installed. Are there fuses in the trailer that control the brakes, any idea where they are?
This forum is great, I am learning a lot from all of the input.
There are no fuses in or around the trailer for lights or brakes on the camper .
That is all controlled by the tv.
Old 06-04-2012, 09:32 PM   #13
Back to the original post, as this has gotten out of hand.
1. You had trailer brakes, but no brake lights or turn signals, is this correct?
2. Now a local dealer replaced the trailer pig tail and now says you have no trailer brakes, is this correct?
3. Now you also have no marker lights, is this correct?
4. You do have brake lights and turn signals, is this correct?
I think we are confused, or at least I am. If you had brakes, and a dealer replaced the pigtail, and now you don't have brakes, he is in very serious violation of the law, as the trailer must have brakes. He should have never let you leave, and you should have never left.
Please give us the rest of the story. Also check your owner's manual for the tow vehicle, there may be fuses to control the trailer wiring separate from the tow vehicle, and if he hooked something up wrong in the pigtail, may have blown a fuse. The towing fuses are generally in the under hood fuse box.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 06-04-2012, 09:38 PM   #14
TURBS's Avatar
what got out of hand ?
Old 06-04-2012, 11:08 PM   #15
Everyone is asking questions. Need to wait on the OP to respond. F1100Turbo made the comment in a post, "too many unknowns" but yet everyone keeps posting without the OP answering the questions. Someone even posted "Most tv use relay for brakes on tt.", which is not correct. Trailer brakes do not work through a relay on the tow vehicle. The charging system may work through a relay, but never trailer brakes, would be illegal in all 50 states. Yes I am a ASE certified MASTER tech for trucks and autos, and a part time RV tech. We need to let the OP come back with the rest of the story.
LadyWindrider
Old 06-05-2012, 06:25 AM   #16
TURBS's Avatar
I did in fact say relay for brakes.
Good catch! I meant for charging system ty.
Been a mechanic for 22 years my self.
2 years of auto diesel schooling
Old 06-05-2012, 11:52 AM   #17
michcamper
From OP, Roo brakes
The whole story, don't get bored. I have had on and off problems with the brake lights and turn signals. A dealer at the RV show said that I should replace the pigtail, because the old one was corroded (sight unseen). I was never aware of any problems with the brakes. I had only a few problems with marker lights, but it was just bulb problems. I bought a new 7 pin pig-tail on line (8 ft.) and had a local dealer install it. While towing from storage to the dealer I did notice some markers out, but no problems with the brakes. Maybe I don't know what not having brakes on the TT should feel like. Anyway, after the new 7 pin was installed the turn signals and brake lights worked just fine. He then told me that the brakes did not work. He had it hooked up to a test box that displayed several functions including brake lights, turn signals, brakes and others I don't remember. He pointed the the brake indicator and it was lit. He said that it was not lit before. He wanted to charge me extra to do further diagnostics. I could not afford to spend addition money for him to poke around. I drove back to storage and did the idle test my son suggested and that seemed to indicate that the brakes are not working. Again, I did not seem to have any problems towing from the dealer to storage, about 20 miles, but I may not know what I should be feeling. I am thinking about another RV dealer looking at it, but I just might be going in circles.
sryan421 is offline   Reply With Quote
Old 06-05-2012, 12:08 PM   #18
TURBS's Avatar
That's why I think u never had brakes. You would definitely know when you do or don't if they ever worked.
You need to get a volt ohm ammeter and start testing your tv connector for all functions.
Using diagrams posted previously you should be able the find trailer brake actuater wire.
Not the same as brake light wire.
brakes, roo, roo23ss
