Old 02-19-2016, 01:10 PM   #1
wicked1's Avatar
Roo Center Island Loose on 23ikss
Anyone have this happen? Went to pick it up fromCW who did a good job on the warranty work and we noticed center island was really loose so they are keeping it another day to fix it?
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 02-19-2016, 02:05 PM   #2
Pill Billy's Avatar
Mine was loose too on the side closest to the kitchen wall. The tech tightened down the screws and so far so good.
Pill Billy is offline   Reply With Quote
Old 02-19-2016, 02:12 PM   #3
wicked1's Avatar
Ok mine was loose on the side of the Kitchen as well seems those things take a beating and they are not very well secured if it happens again I thing I am going to put a few spaced out longer screws in the base of the Island, poor design though.
2015 Roo 23IKSS
Old 02-19-2016, 02:36 PM   #4
DK-in-SC's Avatar
Do your slides hit the island? My dinette slide doesn't touch, but on the kitchen side, the handle on the oven just touches the island. We have a little mark on the cabinet from it and now put a piece of that rubber shelf liner on the oven handle before bringing in the slide. I think that was one of the reasons they made the island cabinet smaller - to avoid things rubbing when the slides are in.
I live with fear every day, and sometimes she lets me go fishing.
2015 Shamrock 23IKSS
2008 Ford Expedition EL
DH-DW-D3K-DMTTSAP
DK-in-SC is offline   Reply With Quote
Old 02-22-2016, 03:17 PM   #5
wicked1's Avatar
Nope fully clears island on Kitchen side by 2-3" and dinette side by 1-2 nothing is touching. They pushed the screws down and added a few as they say this is a simple but common issue with center islands and the one in the Roo is sort of heavy. Brought it home tested it out solid now and only heavy stuff is loaded on the bottom of the island second shelf and top soft light stuff so will keep an eye on it this season.
2015 Roo 23IKSS
Old 02-22-2016, 04:06 PM   #6
gbrian0118's Avatar
23IKSS Center Island
Yes it did. The diagonal panel that is closest to the bathroom had come completely off from the sides and bottom. I read some other posts that said the screws were loose, no screws on mine to tighten they just used staples, staples mind you and behind those staples, nothing just empty space. I got with my neighbor, who is a great cabinet maker, who made me a piece to fill in the void and I put screws in to hold it together.
2015 Roo 23IKSS
2016 Silverado 2500HD Duramax
gbrian0118 is offline   Reply With Quote
Old 02-22-2016, 05:25 PM   #7
wicked1's Avatar
I have screws in mine holding the cross members and frame to the floor, my side panels were stapled into the main frame but those are all tight and flush at the moment. The more and more I read about what these MFG's do to cut corners the more and more I get frustrated what they charge, sometimes the 1/2 ass work I see makes me want to call them and ask how they are still in business but not worth it, just fix it myself and then never have to fix it again. I see where people who are no handy can get frustrated especially when you buy a high end unit, I have a Roo which I don't consider HE bc price is below $25,000.
2015 Roo 23IKSS
Old 02-22-2016, 05:53 PM   #8
Have any of you found the aluminum tubes sandwiched in the floor assembly and anchored the island to those? I'm not sure how far apart they are. In the brochures they say 16" O.C., Select Roo Models. Getting them to tell you what ones are "select" would probably be like pulling teeth. A decent stud finder would work.
The top layer of plywood in the floor sandwich is something like 5/16" or 8mm and not much to anchor to. I'd worry about the island pulling that layer of plywood off the foam its laminated to.
Mr Havercamp is offline   Reply With Quote
Old 03-30-2016, 02:41 PM   #9
wicked1's Avatar
If I remember correctly only the Roo/Shamrock 23IKSS has the center island all others have kitchen on one side or another no island right?
Old 03-30-2016, 06:19 PM   #10
gbrian0118's Avatar
Yes you are correct
2015 Roo 23IKSS
roo
