Old 06-14-2014, 04:45 PM   #11
Ford Idaho's Avatar
Originally Posted by Jimandchris View Post
I'll try again
2014 Roo 23SS & 2013 GMC 4WD Crew
The first one showed up just fine.
Old 06-14-2014, 04:53 PM   #12
Jimandchris's Avatar
Weird, I cannot see the first pic on my tablet....sorry for the confusion. Just wanted to let everyone know that the longer bladed breaker is needed for that green fuse holder. Older posts have mentioned that FR may have wired directly from the battery instead of the converter to save wire and that's why the fuse is separate and not thru the converter.
Jim
2014 Roo 23SS
2013 GM Sierra CC
Prodigy P3 Brake Controller
Equal-i-zer Hitch
Nites Camped 2016 -25
Jimandchris is offline   Reply With Quote
Old 06-14-2014, 04:56 PM   #13
Ford Idaho's Avatar
Jim
Try closing the mobile app and then restarting it, if that does not work then delete and reinstall the mobile app.
Old 06-14-2014, 05:12 PM   #14
Thanks, I've tried that already. My app for the tablet is always stopping unexpectedly. I understand others are having the same issue...
2014 Roo 23SS
2013 GM Sierra CC
Equal-i-zer Hitch
Old 06-14-2014, 05:17 PM   #15
Ford Idaho's Avatar
I know it is an ongoing problem but I'm almost certain the it people are on it.
Old 06-17-2014, 08:09 PM   #16
kpm
kpm's Avatar
Originally Posted by Marine3038 View Post
We have a 2014 Roo 233S -- have had it about 4 months. Took it camping this weekend and the slideout did not work... after an hour of troubleshooting - turns out it was the FUSE LOCATED UNDERNEATH THE FRONT OF THE CAMPER - 30 watt fuse
Wanted to post this in case anyone else has a similar scenario (slideout not working)... I found it unusual that the fuse was located underneath in that location - and there was no mention of this in the manuals or when we did our walk through.
Thank goodness for "Google"
Hope this info helps someone.
p.s.
I also recommend purchasing backup fuses (never thought to do so when we first purchased
Happy Camping
- Jesse
Thanks for posting this. I too had the exact same problem this weekend. As soon as the slide was fully extended the fuse blew. I was able to get it in using the manual hand crank. I agree that this forum and google help with many of the problems/questions. I've found some of the most critical information here. Mainly about that fuse and where to manually crank the slide out. This may sound simple but as a new owner all of that was overwhelming at first.
So I replaced the fuse yesterday and the slide out works perfectly again.
Thanks!
kpm is offline   Reply With Quote
Old 06-22-2014, 04:41 PM   #17
Where would I buy some of these fuses just to have extras?
Sheripoms is offline   Reply With Quote
Old 06-22-2014, 04:58 PM   #18
Are you looking for the fuse or the auto resetting circuit breaker? Circuit breakers and the fuses are at any of the auto parts stores. I found ours at Auto Zone. Using the circuit breaker eliminates having to crawl under the trailer to replace the fuse. Murphy's law says using the fuse it will pop when you get to a campground and it's raining.... LOL
2014 Roo 23SS
2013 GM Sierra CC
Equal-i-zer Hitch
Old 06-22-2014, 07:52 PM   #19
On my list of things to buy.
Thanks!! I didn't know it was located outside the camper either.
2014 Rockwood Roo 233S
2013 Toyota Tundra 5.8L V8 Crewmax
2 girls and 2 dogs
ParrishCamper is offline   Reply With Quote
Old 06-22-2014, 08:26 PM   #20
Bussmann (BP/UCB-30-RP) 30 Amp Type-I Universal Circuit Breaker
This is the circuit breaker some of us have been using to eliminate having to replace that fuse each time.
2014 Roo 23SS
2013 GM Sierra CC
Equal-i-zer Hitch
roo, slide, slide out
