Old 08-09-2016, 11:47 PM   #1
1
Roof
Ok so I have a 2000 shamrock hybrid hyperlite. I was given info on how to tell what type of roof it is but can't figure it out. All the roof has is a rubber type skin that has some type of texture. There doesn't seem to be side rails I can remove. The only thing under the roofing material is 2" styrofoam. How do I determine the roof material. Have a pretty major depression near the ac where water accumulates. And has damaged my entire new ceiling and flooring. Need help asap.
Jmcdev
2001 21' FR Shamrock
Jmcdev is offline   Reply With Quote
Old 08-10-2016, 05:10 AM   #2
World Wide Wanderer
wahoonc's Avatar
Sounds like it might be TPO rather than EPDM rubber. easiest way to check is to take off a roof vent interior garnish and get your hands on a scrap. If it is stretchy it is EPDM, if it is not stretchy and has a plastic feel it is TPO. I would have to see pictures of your side areas, but quite often the roof material is clamped down underneath a piece of trim. It has to be secured somewhere, someway, somehow, or it would blow off running down the road.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
roo, roof
