Old 10-17-2014, 09:16 AM   #11
mark0224's Avatar
Sorry to hear that, In this case I would clean the spot up good smooth the rubber out and clean it good all around the patch area. Use the dicor all over the tear itself and let it dry. When that dries put the eternabond patch over the area carefully folding it from the edge over after its down go around the edge of that with more dicor. Make the patch larger than the area you need.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 10-17-2014, 09:58 AM   #12
VinceU's Avatar
The roof throughout the industry is stated as a "one piece membrane roof". Insurance should 'replace in kind 'IAW typical policies.
Old 10-17-2014, 11:04 AM   #13
mwoods's Avatar
Had a similar hole in the house roof from a tree limb.
It could be repaired like I did the house, except I use shingles on the house of course.
I had some thin flat sheet metal from a left over project, you can buy it at Ace, Home Depot, etc.
Cut a piece of the sheet metal larger than the hole, construction adhesive it in place.
Eternabond to cover the area of the outer membrane and Dicor the edges of the eternabond.
If you dont want to use sheet metal you can use the plastic from a garage sale sign or similar.
TV 2012 Chevrolet Silverado CC 5.3
TT 2007 Puma 30QBSS
Reese 12000 WDH
Reese Anti-sway bar
mwoods is offline   Reply With Quote
Old 10-17-2014, 02:55 PM   #14
Just be careful. Watch the dealer. I live in Ohio and ended up taking our camper back to Forest River to get fixed at 1/4 the cost and a 2 day fix time versus 6 to 8 weeks at the dealer. This was to replace the entire front with bunk.
Les & Heidi Kramer
2010 GMC Sierra SLE & 2014 Shamrock 23IKSS
Cleveland, OH
cpd1343 is offline   Reply With Quote
Old 10-17-2014, 03:53 PM   #15
mud yapster's Avatar
The insurance co. should replace your roof. What insurance co. do you have? If they don't replace it like they should I would file a complaint with the state insurance board, then they will replace it. A complaint causes their rating to go down and they don't like that. LOL
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 10-19-2014, 09:18 PM   #16
My insurance is usaa. I am going to talk to the repair guy again and ask questions. See if they will replace the roof
kim_m is offline   Reply With Quote
repair, roo, roof, roof repair
