Old 12-10-2015, 02:58 PM   #21
I used a 3'' roller attached a push broom handle and used black oil base rustoleum paint....worked great
danc is offline   Reply With Quote
Old 12-10-2015, 03:41 PM   #22
^^X2^^
When looking at some of the models on the dealer lots when ordering ours, almost all of them had very rusty bumper tubes on the inside. I think a lot of the frames sit out in the weather before production and get rusted up.
There are Scotch-Brite pads available at most hardware stores that could be taped or screwed to a piece of 2x4 and shoved back and forth to clean the inside of the bumper. Then tie a rag (or someone mentioned a BBQ brush) to the 2x4, dip it in some Rustoleum and paint the inside.
Earlier suggestions of the plastic 5" fence post with 4" plastic gutter mounted to the frame are the easiest, least labor intensive "final" solution to the problem.
Not "my" idea, but I like it!
pdqparalegal1 is offline   Reply With Quote
Old 12-10-2015, 04:13 PM   #23
bikendan's Avatar
Over 9 years of storing my Walmart purchased sewer hose, in the bumper of our Roo and never had a tear in the hose.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 12-10-2015, 08:40 PM   #24
X2 Wumba....trailering x 20 + years in various units....steel rusts...use a plastic bin or rain gutter in a vinyl fence post.
greymedic is offline   Reply With Quote
Old 12-10-2015, 08:44 PM   #25
Pickin' & Campin'
Sorry for suggesting an alternative then.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 12-11-2015, 07:10 AM   #26
TURBS's Avatar
Same here
5 years on flagstaff with hose in bumper.
5 years with "same" hose in bumper of sabre.
No issues.
Old 12-11-2015, 07:20 AM   #27
KyDan's Avatar
I've always kept the hose in the bumper. 3 trailers over 12 years. Never a problem BUT- I also always use a flat file and de-burr the open end. Often they cut the bumper with a "stone saw" or coarse blade band saw and it leaves a sharp edge which can be either on the outside edge or inside edge of the end. I also believe some square tubing has rough seams inside more than others so your mileage may vary fer sure!
Peace!
Dan & Rita D
Blue Ox WD hitch
