Old 07-31-2015, 12:01 PM   #21
Mr. Dan's Avatar
This thread went from fresh water drain to low point drains when a pic of low point drains was posted early. I only use low point drains to winterize also.
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 07-31-2015, 12:14 PM   #22
Flybob's Avatar
To answer the question on why you might drain everything between trips do the following, Take a short piece ( 12"-16") of clear plastic hose/tubing about 1/2" diameter. Fill it with water from your FW tank. Plug the ends just to prevent water from leaking out. Put it in your RV in a dark spot ( closet or storage space). After about a month or so pull it out and see what you have growing inside.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-31-2015, 12:19 PM   #23
Well here you go. It's not pretty, but it works. Pump comes on and no water leaking now. After looking closer, there is a second hole in the floor (I am assuming where the factory installed the little access panel. I am not putting anything back just yet. Camping like this and will make sure that there are no leaks this weekend.
If you look close, you can see the screw hole at the end by where it goes under the flooring.
Parr8hed is offline   Reply With Quote
Old 07-31-2015, 02:58 PM   #24
Ford Idaho's Avatar
That is just ridiculous.....
Parr8hed that is some good work in getting things squared away.
Old 07-31-2015, 03:06 PM   #25
Mr. Dan's Avatar
I agree! Parr8hed, you're in charge of plumbing failure diagnosis now.
Old 07-31-2015, 04:17 PM   #26
Even a blind dog gets a bone now and then.
drain, tank
