Old 06-25-2012, 10:19 PM   #1
jkinger's Avatar
Second a/c
We like just about everything about our 233s roo but, during the hot Oklahoma summers the a/c just can't keep up. We cover all three tents with space blankets and have reflectix in the windows. I was thinking of adding a second 13.5k a/c or upgrading the 13.5 a/c I have now to a 15k. I think I could run second a/c off separate 20 amp hookup. Just looking for input.
jkinger is offline   Reply With Quote
Old 06-26-2012, 12:12 AM   #2
1l243's Avatar
Do you have an available roof vent where you can put a second AC? I added a second AC to the Garage in my Toy Hauler. Mine was prewired so the electrical was easy.
Your right, if you want to run two AC's at the same time you will have to run it seperate from your 30amp system...
You can see my install here
http://www.rv.net/forum/index.cfm/fu...5.cfm#25971865
1l243 is offline   Reply With Quote
Old 06-27-2012, 10:02 AM   #3
cogito ergo moo
Cowracer's Avatar
I have the 15k btu in my 21ssl. Not a whole lot smaller than your 233 when you factor in the size of the slide. It will positively FREEZE you out. We camped just last weekend, 100 degree days, and our spot was in direct sunlight from sunrise till about 7-7:30 at night. We have no reflectex or space blankets.
To be sure, the bunk ends were noticeably warmer than the main 'box', but only while the sun was up. But on the whole, I think I could hang meat in the thing. I didn't know if another 1.5k BTU in a/c would make a difference, but is sure seems like it does. My old class A with TWO 13.5K did not cool down like this one does.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 06-27-2012, 02:36 PM   #4
jkinger's Avatar
Thanks for input cowracer and 1/243. I have already installed second a/c and will finish wiring it tonight. I plan on wiring in a separate circuit to run it. Camping this weekend in 100 + weather so we will see how it works.
Old 07-04-2012, 09:46 PM   #5
It was 109 in the shade here in Southern IL today and 94 in our camper with the air running! Miserable! Now that the sun isn't beating down it is freezing in here. I ended up putting our tent ends in to help cut down on the loss of cold air. It helped some. We definitely learned our lesson and will NEVER camp in the sun in the summer again. We will also make sure we have the bigger air unit next time (I believe we have the smaller one). Live and learn. Will be getting solar blankets as well. Glad to hear that we are not the only ones with a cooling issue. DH thought the air conditioner broke at first. Hopefully your addition of a second air conditioner helps.
Beth
Nights Camped in 2012 - 88
2012 Puma 31 KBH
2010 Chevy Silverado 2500HD
2008 Chevy Tahoe LTZ
tolley31 is offline   Reply With Quote
Old 07-05-2012, 07:58 AM   #6
jkinger's Avatar
Just got back from a 4 day weekend in 100 plus degree weather. The second system worked great. Used it in afternoon during heat of day. Kept camper at 75 degrees. Second a/c blows right into front bunk. We were in shade in morning but had afternoon sun.
Old 07-05-2012, 11:05 AM   #7
wiesenbornk's Avatar
We are VERY interested in this thread! Right now we are camping on the beach in Texas and it is uncomfortably warm! Anyone know about how much it would cost to get a second AC unit and have it installed? This is our first summer with the Roo and have loved it up until now. I would hate for our camping to come to a screeching halt. HELP!
wiesenbornk is offline   Reply With Quote
Old 07-05-2012, 11:39 AM   #8
Hate hearing others have the same issue as we did with the heat but glad to know we are not alone.
Beth
2012 Puma 31 KBH
Old 07-05-2012, 12:00 PM   #9
jkinger's Avatar
I did the install myself. The 13.5k a/c cost $575. I had the 12/2 wire but had to buy the external plug for about $20. I used the forward vent opening and it took about 4 hours. Also $25 for 25' extension cord.
Old 07-05-2012, 12:33 PM   #10
Where would you go and how much would it cost to have someone do the install for us?
