Old 08-23-2015, 08:17 PM   #1
dudleydoo's Avatar
Service/work light
There is a light, down low on the front of our 23IKSS. We were told it was to help at night around the tanks and hitch. It has never been used and I tried to turn it on tonight and it doesn't work. I can't even figure out how to get into it to see if the bulb is loose or dead. Any suggestions?
Bonnie and Rich
Oconomowoc
Winston (Rat Terrier)
Digby (Lhasa Apso)
2014 Shamrock 23IKSS
dudleydoo is offline   Reply With Quote
Old 08-23-2015, 08:44 PM   #2
urocav2001's Avatar
I had the same issue with my 233s but it would take about 5-6 times to get it to turn on then would be fine, until the next day it would take 5 times again, dealer replaced whole light assembly
urocav2001 is offline   Reply With Quote
Old 08-23-2015, 08:47 PM   #3
dudleydoo's Avatar
Guess I'll go out and try going off and on again. Seems like a hassle to have to take it back into the dealer for that repair. Do you ever use the light?
Bonnie and Rich
Oconomowoc
Digby (Lhasa Apso)
Old 08-23-2015, 08:52 PM   #4
urocav2001's Avatar
No I only tried it out when I got it, but never use it, the contacts may be loose that are suppose to touch the light bulb, or just peek at the bulb itself, the outside light on the side should have the exact same light bulb
Old 08-23-2015, 08:55 PM   #5
dudleydoo's Avatar
Ah, that's another problem.......how do you get inside the light? It has caulk all around the base.
Bonnie and Rich
Oconomowoc
Digby (Lhasa Apso)
Old 08-23-2015, 08:58 PM   #6
urocav2001's Avatar
You stick a small screwdriver in between the clear plastic lens and carefully pry it out.. Be gentle with it and it will pop out. You don't need to take the light assembly off the camper to remove the cover or light bulb
Old 08-23-2015, 09:00 PM   #7
dudleydoo's Avatar
Thank you, I'll check this out in the morning.
Take care,
Bonnie and Rich
Oconomowoc
Digby (Lhasa Apso)
Old 08-23-2015, 09:03 PM   #8
urocav2001's Avatar
No problem
Old 08-24-2015, 05:23 AM   #9
Where is this light? Could you take a photo? Just don't see anything outside.
syogerst is offline   Reply With Quote
Old 08-24-2015, 09:50 AM   #10
urocav2001's Avatar
Should be on the front of the camper lower right corner
light, service
