07-15-2017, 09:08 AM
#21
+1 on the sewer solution. Been using it for years. No need to worry about maintaining a downhill slope with it, No worries about cracked or split hoses, either.
-- My wife complains I never listen to her. Or something like that.
2017 Heritage Glen 368RLHBK Limited
2017 Ram 3500 4x4 Crew, 6.7 Cummins
07-15-2017, 11:20 AM
#22
The one thing I'm not thrilled about with the Sewer Solution is that it uses 4-5 gal to drain every 10 gal according to their paperwork. So draining a 30 gal tank takes 12-15 gal of fresh water. And if you're draining it to a portable dump tank, you've got move that extra water. And if you're boondocking, it doesn't work.
If you're always a full hookups and don't mind using extra water, then you're good.
2011 Traverse LT, 3.6L, FWD
07-15-2017, 11:42 AM
#23
I agree with you regarding the extra water usage not being a good thing.
But, if you're boondocking, you're probably not dumping your tanks anyway (edit...unless you're using portable tanks as you mentioned)
My main concern with the sewer solution is the time it would take to properly drain/flush the system. You wouldn't get the benefit of the big initial surge of water to flush the tank. I'm sure with repeated flushing it would eventually work very well though (back to the problem of excessive water needed).
Eric & Abby
2016 Rockwood Roo 183
2014 Ford Explorer Sport
07-15-2017, 12:07 PM
#24
Originally Posted by ebcobra93
They do tend to be tippy if you don't stretch it out. Once stretched out, I found it to be quite stable.
I used the one with the orange handle in the last picture without any problem. However the one I got from CW had trouble staying upright.
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
07-15-2017, 05:15 PM
#25
You can dump most of the tank with the water off and only turn the jet on if something comes down and doesn't just flow thru. That's how I've been doing it.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
07-15-2017, 05:32 PM
#26
Sewer hose support?
Have used the Valterra sewer Hose Buddy support for several years and it works very well.
Valterra D40-4010 Sewer Hose Buddy 10' Hose Support https://www.amazon.com/dp/B004RCUUH0..._LEPAzbN0BX0B0
2016 Rockwood Windjammer 3029W
2013 F350 Lariat Longbed 6.2L
07-15-2017, 06:15 PM
#27
Plastic gutter and made some 1/2" pvc supports
07-16-2017, 10:10 AM
#28
I use a Camco sidewinder (plastic).
Bill and Gail
2016 Sunseeker 3010DS
V10 6 speed transmission
2017 Ford Fiesta toad
07-16-2017, 11:46 AM
#29
Got sick of using the slinky sewage support. Also because our bathroom tanks are near the front of the camper, a number of times I had a long way to go and sometimes uphill. I made my own this weekend. Went out to the camper to see how it would work. I think this will do alright.
Russ
2016 Rockwood Windjammer 3025W
Diamond Package
2016 Ram 2500 6.4 Hemi 4x4
07-16-2017, 12:26 PM
#30
Senior Senior Member
I only hook my hose up when the black tank is full and then only to dump and flush out the tank then the hose goes back into storage. Used to prop it up and fuss with it but there's really no need. No one does it at the dump station do they? So it's the same to me. Keeping it out of the sun is probably going to lengthen it's life and the campsite looks neater. IMHO, that is.
2015 Flagstaff Super V 26VFKSS Emerald... SOLD
Now camping with a new SOB Winnebago pulled by a 2021 Ford Ranger.
07-16-2017, 01:15 PM
#31
Camco slidewinder
2016 wildwood x-lite 241qbxl
being jurked down the road by the beast 2007 Dodge ram 2500
5.9 cummins g56 Trans southbend clutch and a smarty
07-16-2017, 08:50 PM
#32
This makes sense to me. We're new to having a unit with sewer, so I'm sure we'll learn as we go along.
