Old 09-06-2014, 08:34 AM   #1
BMFLYFISH's Avatar
Sewer odors
I hooked the sewer hose up at the campground but 2 hours later I am smelling sewage odors in my camper. Is this normal? Do you still treat the black tank even though the valves are open?
Thanks Everybody!
Brian
2015 Roo 23IKSS
TV: 2004 GMC Sierra
BMFLYFISH is offline   Reply With Quote
Old 09-06-2014, 08:39 AM   #2
B and B's Avatar
Hello
I would leave the black tank closed till you dump. Depending on the model of toilet some Dometic were recalled for leaking seals. It is possible the trap in the tub/shower drain, might be dry. I would add water to the fixtures to make sure. I know if the bowl doesn't hold water either there is something stuck on the seal or it is defective, i lube the seal with vegetable oil and this helps.
Some people have had issue with vent pipes being broken, look at simple solutions before digging too deep.
Brian
B and B
Old 09-06-2014, 08:46 AM   #3
TURBS's Avatar
As Brian said,
Only open sewer hose when your full and needing to dump.
Black first then grey
TURBS
"SABRE OWNERS UNITED"
Old 09-06-2014, 09:17 AM   #4
Be careful or you will get the dreaded poop pyramid! See below!
https://duckduckgo.com/?q=rv+poop+pyramid
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 09-06-2014, 09:39 AM   #5
There are only 3 times when the black tank valve should be left open,
1 when dumping the tank only when 2/3 + full.
2 when flushing the tank.
3 when I winterized it.
All other times it should be closed. And use plenty of water (don't ask me how I know).
Started Out With Nothing,
Still Have Most Of It Left!
jwedell is offline   Reply With Quote
Old 09-07-2014, 07:16 PM   #6
I've been struggling with keeping the pooper pretty smelling! I agree with keeping the black closed until dumping. The day we are unhooking and leaving I fill the tank with water even if it is 2/3 full to get a full heavy flush out. Then iv'e been adding back about 1/4 tank of water with a citrus drop in and about 1/4 cup liquid dish soap. Don't know if my method is ok, but so far it's been working ok.
hockeyfam is offline   Reply With Quote
Old 09-07-2014, 07:27 PM   #7
Iwannacamp's Avatar
We mostly get "the odor" after I have towed the trailer. Does this sound like the 300 deal?
2017 Puma 297RLSS
Old 09-08-2014, 08:00 AM   #8
DK-in-SC's Avatar
As others have said, black should stay closed until you are ready to dump. If you want to keep the grey tank open, here is a little trick to keep out the stink:
Hope it helps.
I live with fear every day, and sometimes she lets me go fishing.
2019 Surveyor 251RKS
2008 Ford Expedition EL
DK-in-SC is offline   Reply With Quote
Old 09-08-2014, 09:34 AM   #9
Great idea, never thought of that.
Old 09-08-2014, 01:50 PM   #10
BMFLYFISH's Avatar
Thanks for the responses! My initial thought was that there was ample pea traps to keep the smell out. What a "stinky" way to learn a lesson!
Thanks Everybody!
Brian
2015 Roo 23IKSS
TV: 2004 GMC Sierra
Old 09-08-2014, 03:30 PM   #11
kpm
kpm's Avatar
I am new to this, but have almost completed my first season. I have not had any bad odors from the grey or black tanks.
This is my method that I am trying to refine....
1. when I get to the campground, I first dump the 1/3 full tank of treated water from the previous trip.
2. I then backfill the black tank to about 1/3 of fresh water from the campground and add a freshener additive/cleaner prepare it for use on the trip.
3. If the black tanks gets full during the trip, I dump it and fill it back to 1/3 for additional use.
4. When leaving, I make sure that the black tank is full then dump. I back flush a few times until the water looks pretty clear and free of solids.
5. After back flushing, I fill the tank with a little water and add a blue black tank cleaner and deodorizer pack. This treated blue water stays in the tank and sloshes around until the next trip.
My method takes a little while when dumping, but I'm happy because I get no odors. I do an abbreviated version of this for my grey tank.
I like this attachment for all of this.
Amazon.com: Camco 39062 Dual Flush Pro Holding Tank Rinser with Gate Valve: Automotive
kpm is offline   Reply With Quote
Old 09-08-2014, 03:42 PM   #12
kpm
kpm's Avatar
Let me add that I did have an odor on my secon or third trip because I had the bathroom fan running when I opened the toilet trap. I later read on the forum here that doing this creates a situation where the odors are sucked from the black tank.
Also, when I am back flushing the black tank on cleanup day, I have the stabilizers up. I'm assuming that the shaking of the trailer while people are walking around sloshes/agitates the water and solids before dumping. This may be off base, but I thought of it this past weekend. Does this help?
