Old 05-30-2015, 01:07 AM   #1
Shake down trip in my new 21dk
So day one. Set up went ok. Had one problem with the city water connection. No mater how tight I tighten the hose it still leaks. Second problem is with the irv tech Sterio. I tryed to play a DVD it played but in black and white can't get color out of it. On normal tv it works just fine. Does anyone know how to fix these problems???
T2mcnulty is offline   Reply With Quote
Old 05-30-2015, 01:16 AM   #2
For the water connection, maybe a new rubber o-ring? Someone mentioned carrying a pack of various sizes for these types of events.
2014 Ford F-150
2015 Apex Nano 193BHS
2017 Nights Camped: 14
mbCik is offline   Reply With Quote
Old 05-30-2015, 01:19 AM   #3
Ok great thank you. I just filled the water tank and turned on the water pump for tonight. I will get some tomorrow.
Old 05-30-2015, 03:10 AM   #4
If you have Teflon tape on hand that should work in place of o rings.
jkochmit1 is offline   Reply With Quote
Old 05-30-2015, 07:20 AM   #5
RooVader's Avatar
You might want to try a different HDMI cable just to eliminate that as a cause. I am having issues as well with the irv passing the video signal. There are a lot of gremlins in these units but I want to exhaust everything before exchanging.
RooVader is offline   Reply With Quote
Old 05-30-2015, 03:39 PM   #6
Quick Answer For Problem on Water Connection
I usually have a problem getting the water connection set up, therefore decided to go the easy route. I went to Camping World and got a Quick Disconnect/Connect adapter for about $6.00. I now connect the city water fitting in about 5.1 seconds.
Regards,
Rich Kanehl
The Villages Fl.
2015 8280WS Rockwood 5th Wheel
2012 Nissan Titan With Tow Package
RKanehl is offline   Reply With Quote
Old 05-31-2015, 03:46 AM   #7
We use our laptop to play dvd's, computer is connected to tv via hdmi cable and no problems
TinkerToy is offline   Reply With Quote
Old 05-31-2015, 09:32 PM   #8
yetavon's Avatar
Replace your washer, and check if there is any deformity of the thread end of the hose.
Try a different HDMI output, then a new cord. I havent looked but doubt there is a B&W converting setting on the TV.
2015 Shamrock 21DK
2005 Silverado Ext cab
Nights camped 2017.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
yetavon is offline   Reply With Quote
Old 05-31-2015, 09:39 PM   #9
I put a second washer in thank you. That fixed that problem. I still haven't found a b&w setting on the tv or the irv .It's fine on normal tv and cable just is b&w then I put a DVD in.
Old 06-01-2015, 03:45 AM   #10
RooVader's Avatar
It just sounds like a bad cable issue. That would be a very strange defect for source equipment to send out b&w, but pretty common for a bad cable to have color messed up.
XLR 24HFS -> Roo 21DK -> RPod 183g
2013 F150 FX4 EB
