I'm not sure who makes the Shamrock 19, but my Flagstaff V-lite had the same thing happen, the only thing that worked was the power tongue jack, when NOTHING ELSE would. The culprit was a junction block/switch block just behind the tongue on the inside of the frame. If you follow the battery wires, you'll see it. Mine had rust/corrosion on the nuts/terminal connectors that went through this reset -It's actually called a circuit breaker, and SOME.....mine did, have a small reset button on them. The dealer replaced mine, and I'm good now. Randy
