Old 05-19-2015, 04:42 PM   #11
VooRader
The temp control is mounted inside the back of the fridge. No way to get to it without removing the fridge.
dogevans is offline   Reply With Quote
Old 05-20-2015, 09:18 PM   #12
yetavon's Avatar
Guess I will be pulling and looking....
2015 Shamrock 21DK
2005 Silverado Ext cab
Nights camped 2017.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
yetavon is offline   Reply With Quote
Old 05-20-2015, 09:35 PM   #13
TURBS's Avatar
No breaker in the distribution panel?
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "6 nights"
Old 05-21-2015, 09:33 AM   #14
TURBS
The receptacle for the outside fridge is on a 20 amp breaker which includes
all the other receptacles in the camper, including the GFI in the bathroom.
Like other campers I have had, I will be adding a new receptacle dedicated
to running an electric space heater.
Old 04-23-2016, 08:35 AM   #15
Forestriver 21bd fridge & Other
I could see the plug and unplug for winter, However I happen to love the outside fridge, personally I going to just add a power strip with surge protector and switch $15.00 to turn off and on! from my understanding there is a thermostat on off switch on back of Fridge, haven't verified yet! But in any case I contacted Forest river and suggested the add two more cabinet to inside where outside compart is, that way you would have easy access to fridge, plus a place to put trash can and have access from inside and could also be used outside and easily remove from outside for dumping. I may add my self at latter date if I cam find or order 2 doors to match interior! We pick ours up in late November 2015 and only spent one night in it in our yard, next morn canvas had separated from trailer its self at side, so had wobbly table and led lights on jack stand not working took in for warranty work about 6 weeks ago waiting on new swing table leg assembly all other work done. Hope no issue when we go on real first camping trip here at end of May 2016, I had Jayco before this and never had any problems with Bunk ends, Hope forest river quality is has good better
GarFish is offline   Reply With Quote
Old 04-23-2016, 02:11 PM   #16
Robs1968's Avatar
My 2016 DK outside fridge can be unplugged the plug is behind the fridge
Robs1968 is offline   Reply With Quote
Old 04-25-2016, 12:31 PM   #17
I use a standard surge protector. I unplugged my refrigerator and plugged the surge protector into that outlet. I can turn it on or off when ever I want to, and I can also use the surge protector for other items as well.
2007 Ford F150
2016 Roo 21BD
deerhunter21n is offline   Reply With Quote
Old 04-26-2016, 10:01 AM   #18
yetavon's Avatar
I have messed with mine, and found both the plug and thermo control....
both take a contortionist approach to get to, after moving stuff out of the way. I'm seeing a power strip adaptation in my future.
At least you will have 120 power to get to easier.
2015 Shamrock 21DK
Old 04-26-2016, 11:00 AM   #19
RooVader's Avatar
I love my setup. I have a power strip velcro'd on top of the fridge and my bluetooth speaker also fits perfectly on top of the fridge sharing the same power strip. That fridge compartment has become the hub of my outside world.
I was so tempted to remove it because the ONE thing I find lacking in the DK is outside storage...but I use it far too much to consider pulling it out. I sure like some of the innovative ways people are using it though!
XLR 24HFS -> Roo 21DK -> RPod 183g
2013 F150 FX4 EB
RooVader is offline   Reply With Quote
refrigerator, shamrock
