Old 05-17-2015, 09:16 AM   #1
Shamrock 21DB Outside Refrigerator Shutoff?
Just purchased a 2015 21DB and have found that when hooked up to power the outside refrigerator is constantly on. There is no on-off switch on the refrigerator, and the frig is permanently mounted with no way to unplug it. Is there a way to turn it off?
Thanks for any advice.
dogevans is offline   Reply With Quote
Old 05-17-2015, 11:25 AM   #2
RooVader's Avatar
I know others on here pulled the fridge and use it for other things...hopefully a bd or dk owner will chime in. I am curious myself.
XLR 24HFS -> Roo 21DK -> RPod 183g
2013 F150 FX4 EB
RooVader is offline   Reply With Quote
Old 05-17-2015, 05:38 PM   #3
ChibullsAN's Avatar
Reach in and on the right WAY behind the fridge is an outlet. It's plugged into the fridge circuit. I Rewired mine to be on the OUTLET circuit and added a 3 port surge protector with on off switch. This was when I have all kinds of junk packed on top of it it won't run. Cause it gets HOT.
I also removed it for when we dry camp and converted it into a generator storage for traveling and a outside dog area for when the little ones can't come hang outside.
ID:	77246   Click image for larger version
ID:	77247   Click image for larger version
ID:	77248   Click image for larger version
2018 Rockwood Signature Ultralight 8329SS
ChibullsAN is offline   Reply With Quote
Old 05-17-2015, 10:23 PM   #4
Thanks ChibullsAN for the information. I do not understand what you meant by rewiring to an outlet circuit. Could I just plug a surge protector in where the fridge is currently plugged in and then plug the fridge into it? Then use the surge protector as an on-off switch? I think it is pretty cheap of Forest River to install a fridge with no temperature and on-off switch.
Old 05-18-2015, 03:09 AM   #5
ChibullsAN's Avatar
I literally meant rewire the outlet to be on another circuit, as in remove the 110v wiring from one circuit breaker to another in the panel. But I wanted to do that for other reasons..... So yeah adding a surge with on and off switch would work great for you.
Old 05-18-2015, 08:33 PM   #6
yetavon's Avatar
2 trips and some driveway time with ours. We just unplug ours when its not serving as a fridge, but your surge protector idea should work.
2015 Shamrock 21DK
2005 Silverado Ext cab
Nights camped 2017.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
yetavon is offline   Reply With Quote
Old 05-19-2015, 03:48 PM   #7
Thanks for the info yetavon
I tried to unplug the fridge but it was mounted up against the plug.
I removed the fridge, and found that a temperature control and shut
off is mounted behind it. Replaced the fridge with an older fridge I
have that has temp control and shut off inside it.
We are good to go now!
Thanks you all for this forum!
Old 05-19-2015, 03:52 PM   #8
RooVader's Avatar
So you are saying the fridge that came with it has a switch in the back? If so, was it hard to reach?
Old 05-19-2015, 04:25 PM   #9
lablover's Avatar
I absolutely love the dog room but I don't think our 2 labs would fit
2 Old Geezers
2 Labradorables
2015 Dodge Ram 1500-Rambo
2015 Roo 21BD-L'ABode
lablover is offline   Reply With Quote
Old 05-19-2015, 04:38 PM   #10
ChibullsAN's Avatar
Yep. 2 labs would not work out in this...
refrigerator, shamrock
