Old 08-19-2012, 11:01 PM   #1
Shamrock 21ss Replacement Front Light Lens
The lens on the front light (Near the tongue) was cracked after our last trip. I figure a stone chip. Does anyone know if/where we can get a replacement and is it easy to replace? Also, is there a larger table that attaches to the outside BBQ bracket? We never use the BBQ but would like a bigger table. We just purchased this used Shamrock 21ss (2007) and so far have been happy with it. Thanks!
vinson is offline   Reply With Quote
Old 08-20-2012, 05:15 AM   #2
Now is the time to learn how to remove the lens,since it is already cracked. Take it with you to a dealer for proper replacment. Placing a (Larger) table on the rail on the side of the trailer is a bad idea (IF) you place too much total (Weight) on the rail. OJT/RD has found that the screws thru the rail pull out of the trailer side walls,just posted this week! Youroo!!
Old 08-20-2012, 06:49 AM   #3
Triguy's Avatar
I would also take the lens cap to the dealer.
I know what you mean that a larger table would be nice but the bracket attached to the trailer will be the weak point. I haven't seen an OEM table that spanned the width of the bracket but you could make one. You would need the hardware, which is easy to get, a sturdier table, and legs that would go down perpendicular from the outside table corners to the ground. Then the bracket would support much less weight.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-20-2012, 07:04 AM   #4
Mad4sax's Avatar
I just changed my porch light to a clear lens.
Replacement Lens for RVPL5C and RVPL7C Lights Optronics Accessories and Parts APL5CB
It was all of $1.45
It might be the same or if not they should have what you need.
2013 Shamrock 233S
Mad4sax is offline   Reply With Quote
Old 08-20-2012, 08:54 AM   #5
Thanks for the replies and information. Much appreciated.
Old 08-20-2012, 09:07 AM   #6
Mad4sax, Did you remove the whole housing to replace the lens? or was it "snap-in" from the front?
Old 08-20-2012, 09:18 AM   #7
Mad4sax's Avatar
Just snap in and out. One tab on bottom and 2 on the top.
Lens only. (Except for LED bulb replacement on the porch light)
2013 Shamrock 233S
Old 08-20-2012, 09:29 AM   #8
Triguy's Avatar
This is mine. The cover has two tabs on top and one on the bottom. I use a screw driver on the bottom and gently pry up until it pops out (it comes out fairly easy).
Scott
2012 Shamrock 233S
Old 08-20-2012, 09:33 AM   #9
Perfect..thanks!
expandable, hybrid, shamrock
