Old 06-26-2016, 09:01 PM   #1
Should Interior Lights Run on Battery?
We had a power outage the other night for several hours and I thought we'll just go sit in the trailer for awhile and use the lights running off of battery. Although the battery appears to be charged non of the interior lights worked. Is this normal?
Had a nice nice campfire at home instead.
thomsonr is offline   Reply With Quote
Old 06-26-2016, 09:04 PM   #2
wmtire's Avatar
Yes, the lights should run off the battery unless:
1. Your battery is discharged
2. You have a battery disconnect somewhere and it is turned to not allow power from the battery
3. Your resettable fuse that is located usually on the frame rail has tripped
This link may help with #3.
Battery Question
2011 Flagstaff 831 RLBSS
I've invented a new word. "Plagiarism"
Old 06-26-2016, 09:05 PM   #3
bubbles's Avatar
Everything 12 volts should run off your battery (lights are 12 volt). Perhaps you had your battery disconnect engaged (if you have one).
Old 06-26-2016, 09:06 PM   #4
Ford Idaho's Avatar
Lights and fridge should run off the battery and the fridge should start using propane.
Battery disconnect switch?
You unit model would be a help.
Old 06-26-2016, 09:13 PM   #5
Forgot to include 2010 21ss
2010 21ss. During the last safety inspection our local dealer replaced the break away switch and I'm wondering if they did something else inadvertently. I will check out wmtires comment/link tomorrow.
Old 06-26-2016, 11:01 PM   #6
Moderators' Assistant
bikendan's Avatar
As far as I know 2010 Roo/Shamrock hybrids didnt have a factory disconnect switch.
Unless a previous owner installed one.
Dan-Retired Firefighter/EMT
2016 PrimeTime TracerAIR 255, pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 06-26-2016, 11:10 PM   #7
Too old to be too smart
SpringerPop's Avatar
The break-away switch, if inadvertently pulled, will drain the battery quickly.
If your rig sat for long at the dealer's service department waiting to get a new switch, the battery may have completely discharged and sulfated.
If the trailer hasn't been on power (that would allow the battery to re-charge if the converter is on), there's no guarantee the battery is any good.
Pop
2004 Terry 250RKS, perfect for the two of us and the pups. It recently replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 06-27-2016, 02:35 PM   #8
Boondocking Only
ddbck's Avatar
Yes , the lights should work on just battery power.
ddbck is offline   Reply With Quote
Old 06-27-2016, 03:22 PM   #9
rsdata's Avatar
My 2014 Shamrock (Roo) has a 12V shut off switch below the fridge. It is a push-pull switch, unmarked and not part of the converter, although it is near it. Pulled out it provides 12V power to everything... pushed in nothing gets 12V power except the electric power jack by the hitch outside.
2014 Shamrock 183
2014 RAM 1500 SLT Crew Cab HEMI 3.21 8 Spd 4X4
Old 06-27-2016, 03:32 PM   #10
bikendan's Avatar
See post #6.
battery, light
