That water you're seeing is what PREVENTS a stinky bathroom. There should be a P-trap in the drain, similar to what you can see under your kitchen sink. It goes down, then curves up, then back down again. The curve is designed to hold a little bit of water. This small amount of water is what keeps "sewer gas," i.e., the smell of your grey water tank, from coming up out of the drain. So I think you're OK. How to fish the pin out of the trap, though I'm not sure. You could try using a plumbers plunger on it to force the water through the trap. It might take the pin with it into the grey tank. If not, removing the water might at least let you see the pin and be able to pull it out with some mechanical fingers, like this:
Mechanical Fingers Pick Up Tool - CTA Manufacturing | FCP Euro
2011 Traverse LT, 3.6L, FWD
