10-21-2013, 02:19 PM
Shower Faucet Problem
Forgive me if I use incorrect terminology, I have no idea what I'm doing here LOL. I have a 2011 Shamrock 233S that is currently out at my deer lease. Last weekend I took my son and a buddy of his out there. While my son's buddy was using the shower, he managed to completely remove one of the faucet controls, including the internal valve with the handle still attached. I'm guessing since one turns clockwise and the other counter-clockwise he thought he was turning it the right way.
I shut off the pump and found the grommet that goes on the inside of the valve housing. I inspected everything and by looking at the other valve it looks like it was all intact. I put it back together and now the valve will not fully shut off. When turned "off" water still comes through. I tried turning the valve 180 degrees. There are small slots on the sides of the valve housing where the valve lines up. Same thing.
There is a panel around the faucet held on by four screws. I tried removing them so I could take the whole assembly out to bring home, but when I tried to pull the assembly out there wasn't much wiggle room. Only an inch or so and I didn't want to break anything so I put it back together.
Any idea what could be wrong with the valve?
Should that whole assembly come out a way from the wall so I can get to the connections? If not how do I remove it?
Assuming I can get to the connection behind the faucet, is my best be just to spend $20 on a new faucet control? If so, any recommendations?
Thanks,
Larry
10-21-2013, 04:21 PM
Originally Posted by LarryCopper
That is OEM in my camper. All my faucets are that unit.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
10-21-2013, 04:37 PM
Larry,when you replace the shower controls,point the threaded hose output pipe in the Down position.This will allow it to drain properly for winter,also the hot & cold valves will now turn (Properly) like in your home. Your boys buddy made the same mistake many other RVers make ,on direction to turn the Knobs! Youroo!!
10-21-2013, 04:41 PM
Pic for above. Youroo!!
10-21-2013, 05:20 PM
Good to hear! Good idea on turning it upside down so to speak.
Thank you very much for taking the time to write this up.
Appreciate ya...
Larry
03-19-2014, 09:41 AM
What is the purpose of turning the threads down? Does it increase flow/pressure?
Sent from my VS980 4G using Forest River Forums mobile app
03-19-2014, 10:22 AM
This...
03-19-2014, 01:12 PM
Want to come do mine? :-D. This is next on my list, when it's turned off, I get a trickle of water running though.
Kristina
2016 Rockwood Premier 2317G
2021 F150 XLT
Previously:
2005 Fleetwood Seapine, 2012 Rockwood Roo
2015 Sunseeker, 2017 Fleetwood Pace Arrow
