Old 10-22-2012, 08:05 AM   #1
Athens-M50's Avatar
Shower Faucet replacement...Help!
Ok guys....I am kind of stuck.....we broke the HOT side of the faucet in the shower over the summer the last time we went camping......I started taking it apart yesterday...but am know looking for some help....BEFORE I BREAK SOMETHING!.....I have taken everything off that I can....but it will not "Let go" of the wall?
I thought that when I took the 4 screws where it attaches to the wall....that it would come off......should I pry there?????
Thanks for any input!....
2002 17' Shamrock
2001 F150 Ext Cab
________________
2012 nights camped 6
Athens-M50 is offline   Reply With Quote
Old 10-22-2012, 08:50 AM   #2
Us a razor blade to break the seal on the adhesive! Youroo!!
Old 10-22-2012, 10:11 AM   #3
Athens-M50's Avatar
So the connections are in inside that part?
will try this afternoon.
thanks,
2002 17' Shamrock
2001 F150 Ext Cab
________________
Old 10-22-2012, 10:22 AM   #4
I just took mine off about a month ago. Once I removed the screws I had to use a knife to cut through the caulking around the base. I can't tell if yours is caulked or not, I'm betting it is and after cutting through the caulk it should come right off.
Len & Cheri is offline   Reply With Quote
Old 10-22-2012, 10:53 AM   #5
Athens-M50's Avatar
it must....it was not coming off......will try that!
2002 17' Shamrock
2001 F150 Ext Cab
________________
Old 10-23-2012, 03:04 PM   #6
Athens-M50's Avatar
we...that did the trick....
BUT when I was taking off the faucet...the water lines fell back into the wall....so I will have to hook up water to see if I got the Hot on the Hot side and cold on the cold...errrrrrr
2002 17' Shamrock
2001 F150 Ext Cab
________________
Old 10-23-2012, 07:49 PM   #7
caper's Avatar
Are your water lines not colored? The water lines in our trailer are red and blue.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 10-23-2012, 08:30 PM   #8
RED HOT, BLUE COLD.
Old 10-24-2012, 07:58 AM   #9
Athens-M50's Avatar
Both lines blue....... goob
2002 17' Shamrock
2001 F150 Ext Cab
________________
expandable, faucet, hybrid, shamrock
