Old 06-10-2015, 10:49 AM   #1
wicked1's Avatar
Shower Water Restrictor Where is it on a Roo
Ok so took shower head and hose apart but where does the water Restrictor sit on a Roo? Mine is new but need more water coming out
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 06-10-2015, 11:21 AM   #2
BamaBob's Avatar
IMHO, ditch the whole 'stock' shower head/hose and buy a Oxygenics (You can search the forum to read the praises this shower gets)
Oh and you might want one of these too (will allow you to boost the PSI up to 50-55 for that satisfying shower feeling )
Robot Check
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 06-10-2015, 11:43 AM   #3
Originally Posted by HSVBamaBob View Post
...Oh and you might want one of these too (will allow you to boost the PSI up to 50-55...
Never seen one that would boost the psi, all I've seen would only lower the pressure.
To the OP, there is usually a ss disc with a hole in it at one end of the hose that needs to be discarded.
Old 06-10-2015, 11:55 AM   #4
wicked1's Avatar
Robot Check
Had one of those and the fitting came out and MFG would not send me a new one after paying like $55 at CW. I am fine with my 55psi on my current regulator...
Thanks OC will have to pull the whole thing apart if not I may get a new shower head bc hose on factory one is horrible will not bend. I had a braided line in my Shasta it was so much better
2015 Roo 23IKSS
Old 06-10-2015, 12:15 PM   #5
WestCoastRV'er's Avatar
Thumbs up
Robot Check
Oxygenics showerheads are awesome. Well worth the cost.
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 06-10-2015, 02:18 PM   #6
My restrictor was where the hose threads on the base. I took it out, drilled the hole bigger and have plenty of water flow. We don't dry camp so water usage is not a concern.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-16-2015, 03:38 PM   #7
I have an oxygenics shower head and it was great. Then I removed the restrictors both from the head and the shower faucet assembly and now it is AWESOMER..hahaha. OP, mine was right inside the shower faucet assembly. I removed the shower hose and there it sat. I took the one out of the outside shower assembly too. What a difference it made there! That one was just pathetic, so I switched the inside shower head and put it on the outside shower hose...much better!
2014 Rockwood Roo 23IKSS
2012 Dodge Ram 1500 Hemi 4X4
Me, Hubby and Luna the Lab
sewingcybermom is offline   Reply With Quote
Old 06-16-2015, 07:02 PM   #8
wicked1's Avatar
Good to know guys tomorrow is the tears own before my long 2 week trip, I leave my Grey tank open during showers and without a water Restrictor, it should be a much better shower experience so thank you all.
Next upgrade is the Oxi shower head
2015 Roo 23IKSS
roo, show, shower, water
