Old 06-13-2019, 05:07 PM   #1
Shurflo 4008 not pumping on shamrock 233s 2014
Hi guys I've full up my fresh water tank and I can't get any water with the 12 volts water pump. If I'm hookup on the water city everything run fine. I've remove the filter on the pump and it clean. I'm hearing the water pump but I'm not sure if it's running normally as I don't use it often. Any ideas what to do
ThanksClick image for larger version
ID:	207226Click image for larger version
jfguenet is offline   Reply With Quote
Old 06-13-2019, 06:22 PM   #2
ThanksAttachment 207226Attachment 207227
Ha never mind it's working now I've wait a 30 minutes after filing the fw tank and now everything work ok
2014, 233, 233s, pump, shamrock
