Old 08-10-2016, 06:32 PM   #31
WolfWhistle's Avatar
I have the Andersen leveler (2 each) and always carry a piece 4' x 12" (MOL) 3/4" marine plywood. Using the plywood keeps the leveler(s) from sinking into the sod / dirt / gravel and the smooth surface protects the levelers, IMO. If I need to level more than plywood only, I pull forward so the front axle tire is still on the plywood, but just barely; then place two levelers behind each tire on the low side and back up until a second set of eyes tells me I am level, (looking at a stuck on level) then place the chocks to hold them in place. On many tandem axle trailers the tires are too close to fit the Andersen between them, so on those trailers, you can only use one leveler, but it still works, just not as well. When leaving, back up slightly to get the weight off the chocks and pull them out, then go forward off the taper end, not off the high end like the video shows. That also might be how the leveler gets broken ... if jams between the trailer and the ground somehow (if possible). Until I made use of the plywood, I thought these levelers were useless with soft ground; I mean; whats the point of leveling only to have it sink deeper into the earth?
I also have their Rapid Jack... it works the same as the levelers but lifts higher. It seems to me, that using the Rapid Jack would also work for leveling, and save you $$$ using it for both purposes. You would need a chock that the Rapid Jack doesn't include.
WW
XLR Hyperlite 29HFS
Ram 2500 6.7L CTD
Triumph Thunderbird
A Modder's work is never done!
Old 08-10-2016, 06:43 PM   #32
levelers
Does the trailer not have scissor jacks or stabilizers?
For my MH I use rubber pavers that I bought from a home improvement store. They are made from ground up tires and do not absord moisture like wood does.
markb422 is offline   Reply With Quote
Old 08-10-2016, 06:52 PM   #33
Stabilizers are not designed to lift the trailer and will be damaged, if you try.
WW
XLR Hyperlite 29HFS
Ram 2500 6.7L CTD
Triumph Thunderbird
Old 08-10-2016, 07:18 PM   #34
wbdavey's Avatar
I use 2X8 boards with a 45* bevel cut on the ends and also have noted that the trailer needs at least one board under the slide side to be level even on a perfectly flat driveway. Trick I learned on this forum was to put a 2 foot level on the back bumper, place 1/4" wedges under the low end of the level until it's slightly above level on the slide side. Each wedge requires 1" of wood under the tires on that side.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 08-10-2016, 08:26 PM   #35
john5646's Avatar
Anderson levelers are awsome , ( haven't been paid to say that) they just work and work well at what they do. Additionally I feal they cradle the tire and create stability. I have even set up were they were not thick enough so I just rolled from them to solid wood for even more height... Click image for larger version
Name:	ImageUploadedByForest River Forums1470878780.354015.jpg
john5646 is online now   Reply With Quote
Old 08-10-2016, 09:19 PM   #36
Andersen levelers, all day
menekaunee is offline   Reply With Quote
Old 08-11-2016, 08:35 AM   #37
Wanna Be Camper
SaskCampers's Avatar
Originally Posted by tomrob1161 View Post
A problem with side to side leveling, I guess as a result of the Torflex axle, which seems to give a softer ride for the trailer, but doesn't seem to support the trailer as well with the slides extended. You get the trailer level side to side, let out the slides then the side with the slides is lower. You have to plan ahead and have the slide side a little higher to compensate for it dropping after the slides are extended.
We have 2 slides on the same side and I always make sure the slide side does sit a bit low, that way when it rains the rain will run to the outer edge of the slide and not try to come in the trailer.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2013: 16 2014: 5 2015: 3
Old 08-11-2016, 08:49 PM   #38
Left over 4X10 cedar beam cut 12" long. Two for levers and one for the tongue jack. Click image for larger version
Name:	ImageUploadedByForest River Forums1470966532.766030.jpg
2015 ROO 233S
2013 F150 Eco Boost
1Roo4Ladds is offline   Reply With Quote
Old 08-11-2016, 09:04 PM   #39
Originally Posted by dgeck56 View Post
...I also suggest you attach small levels on the front and side of your unit to insure the unit is leveled. I also believe you will notice less shifting or rocking when we inside.
I mounted the large level on the front of the 5er and can see from the drivers seat how much I need. I usually try to move the trailer to a spot that is pretty close to level. The big level is also adjustable side to side as well as front to back level.
Old 08-11-2016, 10:10 PM   #40
Take The Road Less Travld
MuddauberE's Avatar
I carry 1x6 decking boards 3 foot long in the back of the trailer. I have 4 of them and never needed more than 3.
"Take The Road Less Traveled"
2013 Rockwood Roo 233s
2013 Ford F150 FX4
I've been an RVer since 2007, Lifetime Camper
Gotta love the Outdoors, Disconnect and Enjoy Nature!
MuddauberE is offline   Reply With Quote
leveling
